Old 04-02-2014, 04:41 PM   #1
ang31ito
ang31ito's Avatar
Drives: Scion FRS 2013 - Whiteout
Stock rims +coilovers +spacers +LCAs
I just ordered BC coilovers from reworks to get the ball rolling. When they come in, they will also be installing them for me. I've been looking into spacers since I'm keeping the stock rims for now. Does anyone have any suggestions? I've seen most are recommending 20mm front and 25mm for rear with the stock rims. I may be heading that route also. I've seen the existing threads about this already and no one talks about stock rims +coilovers+spacers+LCAs. Any pics? Did anyone not use LCAs with this set up?
ang31ito is offline   Reply With Quote
Old 04-02-2014, 04:47 PM   #2
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
You'll want the LCAs if you're doing anything more than an inch drop for the camber adjustments.
Spacers are a must in my opinion, otherwise your car will look like this:
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 04-02-2014, 04:52 PM   #3
ang31ito
ang31ito's Avatar
Thanks for your input. Do you have any pics lowered more than an inch with stocks, LCAs and spacers?
Old 04-02-2014, 04:54 PM   #4
f0rge
Sorry I don't have anything with spacers since those are just my winter rims, those pics are lowered 1.4inches with LCAs.
Old 04-02-2014, 04:54 PM   #5
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
I don't get what's wrong with the picture above. Is it just you guys are looking to keep the wheels flush even though they are set slightly in when stock?
Toyarzee is offline   Reply With Quote
Old 04-02-2014, 04:55 PM   #6
f0rge
Essentially yes, once someone posts a pic with spacers you'll see how much better it looks (which i guess is a matter of opinion)
Old 04-02-2014, 04:58 PM   #7
dbrandt01
Drives: none
I chose not to run spacers. I know the downsides from the truck world with them.
I have BC Extreme drops and stocks. Just installed last week. I will get LCAs at some point. Rears are worse than fronts though. I don't mind them tucked in.
dbrandt01 is offline   Reply With Quote
Old 04-02-2014, 05:00 PM   #8
ang31ito
ang31ito's Avatar
How low is that drop?
Old 04-02-2014, 05:03 PM   #9
dbrandt01
Drives: none
It dropped around 2 1/4" I think. I can go lower too, but that's pushing it getting in the driveway. Here's measurements, you'll have to measure your stock one if you want as well
Back
Front
Side
Passenger front
Passenger Rear
Old 04-02-2014, 09:50 PM   #10
Toyarzee
Shibby!
Toyarzee's Avatar
great detailed pictures, thank you.
So are the LCA options available going to be adjustable to accommodate adjustable height coilovers?
I assume correcting the camber with just LCA's will further tuck in the entire wheel, which leads to the desired spacers? I dropped my boosted mini tacoma 7" on custom suspension... taking such measures as replacing control arms on an approx. 1-2" drop is relatively new to me.
Thx OP, i was looking into your same questions and your thread opened the door. BTW, Are all people who want to both lower and track the car needing to upgrade rear axles, as other threads have covered? or just the slammed guys?
Old 04-03-2014, 11:27 AM   #11
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
LCA for the rear help to reduce the amount or rear camber you get when you lower the car. I only dropped my car 12.5-1.5 inches and the rear wheels have -2.5 camber.
The spacers just help to make the wheels/tires more flush with the fenders, but since they are needed you could always lower the car and then decide if you want/need spacers.
Depends how low you go...rear axles aren't really the issue, its the angle they have to work(so if you angle the aftermarket/stronger axles they can still break too). When you lower the car, it puts more stress on them. If you are serious about tracking, you probably wont be slamming your car anyway. But, right now, the only option we have is for diff/subframe risers(if you want to properly deal with it). However, with the risers you have to drop the whole subframe to get everything in properly.
I wouldn't worry about the diff/subframe risers right now though.
Old 04-03-2014, 11:46 AM   #12
NemeGuero
http://partsshopmax.com/page.php?36
they have spacers and have specifically used them for flushing the OEM wheels on the FRS.
NemeGuero is offline   Reply With Quote
Old 04-03-2014, 04:22 PM   #13
ang31ito
ang31ito's Avatar
Great responses guys. Since LCAs are visible from the rear I want to go with either black or red to match my colors. Can anyone recommend any good ones? Also, what's the difference between LCAs and camber arms?
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
FS: 4x stock FRS rims + 2x stock BRZ rims = $300 + shipping retrosmiths Wheels and Tires 3 08-13-2013 07:18 PM
Spacers with RCE Yellows on Stock Rims/Tires? husker741 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-04-2013 04:21 AM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
