View Poll Results: Do you have a cutoff switch
Yes - cheap manual under $50 2 12.50%
Yes - cheap manual with alternator protection 6 37.50%
Yes - Electrical solenoid 0 0%
Yes - Electrical solid state 6 37.50%
Yes - Other 0 0%
NO - Shit doesn't happen to me 2 12.50%
Voters: 16. You may not vote on this poll
Old 06-01-2015, 09:59 PM   #1
philooo
Drives: 13' Scion FRS Track car
Battery Cutoff switches ? post your setup
I am looking into a battery cutoff switch.
But there are so many out there, I am curious which one you use:
-> $10 cutoff of the negative battery cable ([ame="http://www.amazon.com/Support-Battery-Isolator-Disconnect-Switch/dp/B00U5UBQE4/ref=sr_1_8?ie=UTF8&qid=1433210293&sr=8-8&keywords=12v+battery+disconnect+switch"]here[/ame])
-> $70 cutoff with alternator protection (here)
-> $200 electrical solenoid system (here)
-> $400 solid state systems (Cartek)
Feel free to share your wiring setup
Thanks.
philooo is offline   Reply With Quote
Old 06-01-2015, 10:33 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
In the race car I run one with alternator protection. In the other cars I don't run one at all. I might put one in the track car but that's because I can't get out of the damn thing when it's on the trailer unless the window is down, then I can reach the switch but have to leave the key in it.. so yeah..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-01-2015, 10:36 PM   #3
puma
crew chief
puma's Avatar
Drives: Race car FR-S
wow now that is an expensive system, all we use is the cutoff with the alternator protection, why do you want all the rest? You also need to wire something that will kill the engine on the switch like ignition coil or injectors.
Just put the switch close to the window if you want a corner worker to be able to handle it.
What is the point of a cutoff on the ground?
puma is offline   Reply With Quote
Old 06-01-2015, 10:38 PM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Who was this to?
And technically I prefer 2 cutoffs. One for a corner worker on the right hand side, and one for a corner worker and driver on the left side.
I generally wire to IGNSW to kill ECU/FUEL/etc.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-01-2015, 10:45 PM   #5
puma
crew chief
puma's Avatar
i was answering the OP, when i posted yours came up at the same time.
I have yet to see someone needing this so we didn't really bother going all out on a system where corners worker can kill it on both side. I guess if this is what you want than you kinda need the electrical stuff to kill it remotely.
Old 06-01-2015, 10:50 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Also depends on the rulebook you need to follow (if you are running with a sanctioning body that requires one). Last I checked, CCWS for example requires it to be reachable by the driver and in the middle of the car, or two, one outside and one center inside. As a legal workaround we have ours on the right side with a big steel cable pull to the drivers side and stickers/ID on both spots so it can be pulled from either side easily and from the driver. Works well for just about any way you can stuff the car into the wall.
I've seen an IT7 car years ago with the kill on the pass cowl, hit the wall hard on the pass side, cut a fuel line and the workers could never get to the switch (buried under tire wall). Driver got out but the car kept pumping fuel to the fire and was a total loss.
Ever since then I like to be able to access it from both sides - just in case. Still just a $70, no need for anything fancier.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-01-2015, 10:56 PM   #7
puma
crew chief
puma's Avatar
yeah we thought about the wire thing too.
I have seen a guy with a cutoff on the wiper cowl too but he received something in the windshield (piece of debris) and the cut off went to off. He obviously had to stop the race because he wasn't able to reach to it and wasn't allowed to unstrap to go shut it close to finish the race.
Old 06-02-2015, 08:30 AM   #8
philooo
The more expansive electric one allow you to only run a small switch wire to any location where you want to add a cutoff switch.
The cheaper switch force you to run a very large gauge cable back and forth to the switch location, not ideal.
But I assume the compromise is to keep the switch near the battery area, to limit the number of big electric cables and then run as many 'pull cables' as needed anywhere in the car (driver side, passenger side, center console). These 'pull cables' are pretty small I guess.
If the electrical solution were cheaper I think they would be a no brainer though...
Still last question anybody can show me where they connect to the alternator ?
Did you run a cable from you switch to the alternator and mount it there ? did you tap into a wire in the fuse box ?
Old 06-02-2015, 09:05 AM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Resister is added to the wiring to burn off additional electricity. You wire from alt to switch and then switch to fuse box where the alt went. That's off 5 year old memory but should be about right.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-02-2015, 09:32 AM   #10
puma
crew chief
puma's Avatar
http://www.rallyanarchy.com/phorum/f...ec_install.jpg
just put the switch between the battery and the positive terminal, take a wire from the positive side and wire it to the small contact and the other side of the contact goes to the resistor to the body.
What this does is that when you open the switch, battery stops feeding the car but the alternator still runs so the other contact needs to cut the engine (coil or injectors) and then the excess current produced by the spinning alternator will drain in the resistor where the contact closed when you opened the switch. (kinda hard to explain but the drawing will explain better.)
Old 07-09-2015, 06:55 PM   #11
philooo
I will certainly be using one of these 6 pole switches. But now my problem is where is a good place to cutoff ignition and fuel ? the switch call for "igntion switch and coil"
I assume the fuse box under the hood has a wire I could connect to, which when disconnected would stop the ignition and fuel by acting at the DME level.
I saw this cool DIY on the porsche forum, I hope someone with knowledge of the FRS electrical system can help me out.
http://rennlist.com/forums/964-forum...right-way.html
The BRZ electrical diagram is online but it is chinese to me
Old 07-10-2015, 11:25 AM   #12
philooo
from what I can see the fuse EFI(IGN) should take care of the ignition and the fuse F/PMP should take care of the fuel pump. But, I am still thinking there may be a better place to cut everything but cutting power to the DME, but so far I am not sure where that would be
I hope @chasebay can help us
Phil.
Old 07-10-2015, 04:21 PM   #13
puma
crew chief
puma's Avatar
i beleive i put mine on the 15A IGN, when you cut that signal you shut down the engine because it won't make ignition, that is all you need a signal to shut down the engine and the rest of the car becomes out of voltage because of the switch so as safe as can be.
Old 05-13-2016, 09:26 AM   #14
philooo
Even though my car is up for sale I will be installing a killswitch on it in order to pass the NASA inspection, hopefully it will help resale value a bit.
I have prepared a shopping list with all the stuff I need, I found some interesting stuff on amazon so I wanted to share with you and see what you think.
I will use the 6 pole switch many of you have been using.
I was wondering what to do with the 2 fuse embedded in the battery positive terminal (graph below) and I found an interesting solution with the 'blue sea dual fuse block'. that should allow me to ditch the battery terminal and connect each cable to their own set of fuse, within a compact block that may be able to be connected directly to the switch. they did not have 140A so I went with 150A. Luckily they had an 80A for the other cable. It is very pricey but it offers 5 low amp fuse for the future.
i am planning for the switch to be located very near to the battery. So I found some remote control cable to have a disconnect on the driver side wiper cowl and place the official emergency sticker there.
the big thing will be to mount the switch neatly and have the whole thing waterproof. I may shop for some kind of plastic box for small battery.
After that I'll run some small 14gauge wire to the previously mention fuse to cut off ignition.
Tell me what you think
4350rpm rev cutoff after car crash diodelphi Issues | Warranty | Recalls / TSB 9 02-26-2015 01:07 PM
Post Pictures of Your Trunk Setup mackdaddytran Electronics | Audio | NAV | Infotainment 10 04-18-2014 10:01 PM
Shorai Lightweight Battery and #Lighterisbetter CNC Machined Tray - 6.75 pound setup KCMachine Groupbuys 73 02-27-2014 01:04 AM
Window switches not working right after battery swap jonbonazza Issues | Warranty | Recalls / TSB 9 01-10-2014 02:50 PM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
