Old 06-01-2015, 07:01 AM   #1
atledreier
Drives: GT86 DGM
Optimal toe for daily/occational trackday
Had my car in at the dealership after I lowered it. They are technically within spec, but the toe is as close to 0 as they managed, and as a consequence my car is very nervous at speed and VERY sensitive to any ruts and poor roads.
What do I want to aim for for a nice stable high speed setup? I'd rather sacrifice a little turn-in to benefit motorway stability.
atledreier is offline   Reply With Quote
Old 06-01-2015, 08:02 AM   #2
wparsons
wparsons's Avatar
What are the actual specs you ended up with?
0 front toe and about 1/16" rear toe in isn't unstable on the highway, sounds like you might have some toe out?
flickr
The Following User Says Thank You to wparsons For This Useful Post:
sittinSideways (06-02-2015)
Old 06-01-2015, 09:20 AM   #3
fika84
fika84's Avatar
@atledreier Being sensitive to ruts typically has to do with camber, not toe. Your tire isn't sitting flat on the ground to just go over the grooves. Instead it is cambered in and will be more likely to follow in the grooves.
fika84 is offline   Reply With Quote
Old 06-01-2015, 09:45 AM   #4
Koa
please post your alignment specs for reeeeal.
I'm -1.1 camber/toe out fr & -1.5 camber/toe in r no glaring issues at highway speed
Old 06-01-2015, 11:36 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
What are the actual measurements? toe out in front. toe in rear. my car feels great.
Awesome turn in. Zero nervous feeling on bumps or cruising.
The Following User Says Thank You to ZionsWrath For This Useful Post:
CSG Mike (06-01-2015)
Old 06-01-2015, 11:44 AM   #6
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
What wheels and tires are you using?
Sleepless is offline   Reply With Quote
Old 06-01-2015, 11:50 AM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Just FYI, I have practically zero toe front/rear but a lot of camber.
My car is "very nervous at speed and VERY sensitive" to imperfections and crowns in the road.
http://www.tirerack.com/tires/tirete....jsp?techid=47
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
fika84 (06-01-2015)
Old 06-01-2015, 12:13 PM   #8
atledreier
Drives: GT86 DGM
Measured values after the alignment:
All values are left/right side and degrees
Front:
Caster: 5:48/5:54
Camber: -0.24 / -0.36
Toe: +0.03/+0.03
Rear:
Camber: -1.54/-2.24
Toe: 0.0/0.0
So, it seems the front toe is actually very slightly positive, not sure if this is out or in, it doesn't say. The spec says minimum -0.45 and max +0.45 degrees, again, doesn't really give me anything to determine if it's in or out.
The rear camber stands out as very uneven, but apparently that was the best they could do with no adjustable rear arms.
The car is lowered just shy of an inch, and I run 20mm spacers front and 25mm rear. Stock wheels, 225/45-17 Michelin Pilot Sport 3 front and rear.
Old 06-01-2015, 12:21 PM   #9
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
You want a bit of toe in at the rear for stability. Probably should get some rear LCAs to fix the camber.
Old 06-01-2015, 12:49 PM   #10
atledreier
Drives: GT86 DGM
So the front toe isn't causing this?
Old 06-01-2015, 12:55 PM   #11
KoolBRZ
KoolBRZ's Avatar
Front:
Caster: 5:48/5:54
Toe: +0.03/+0.03
Rear:
Camber: -1.54/-2.24
Toe: 0.0/0.0
The stock specs have so much leeway that it can be between undrive-able, to stable, but scrubbing rubber. I tell my alignment tech what to align it to. I ask for 1 degree negative camber on the front, 0.00 degrees toe. As close to even camber on the rear as possible with stock LCA's, and .05 degrees toe-in on each side for a combined .1 degree toe-in on the rear only, no toe-in at all on the front. I get mine aligned after every suspension change.
Old 06-01-2015, 01:00 PM   #12
fika84
fika84's Avatar
If you have stock LCA's in the rear there is no camber adjustability, unless you've got some special bolts or something else going on.
Old 06-01-2015, 01:48 PM   #13
Front:
Caster: 5:48/5:54
Toe: +0.03/+0.03
Rear:
Camber: -1.54/-2.24
Toe: 0.0/0.0
add a tiny bit of toe-in in the rear for the car to self-stabilize to a degree street driving. Keep in mind that this also causes the rear to self-stabilize when you're taking hard corners, fighting against rotation, so it's a double edged sword.
DustinS (06-01-2015)
Old 06-01-2015, 07:52 PM   #14
KoolBRZ
KoolBRZ's Avatar
Don't you mean "self-stabilize to a"(bit)"street driving"? Since the measurements are in degrees, using the word degree as an adjective as well could be confusing.
Optimal tire for 17" rim RealShkillz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 10-20-2015 04:18 PM
what is the optimal rim and tire size for 1/4 mile? Mike Brz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 93 02-09-2015 11:17 PM
optimal settings for frs bespoke jkr Electronics | Audio | NAV | Infotainment 9 08-27-2013 05:27 PM
optimal RTR setup scottynoshotty Tracking / Autocross / HPDE / Drifting 28 03-03-2013 01:05 AM
Optimal tint (California mostly) Oriental Life Southern California 49 08-17-2012 07:05 PM
