Old 02-25-2013, 10:40 PM   #1
scottynoshotty
scottynoshotty's Avatar
Drives: Hot Lava 2013 Scion Frs
optimal RTR setup
So this might sound like a stupid question..but if your planning on staying in Stock rtr class what is the most you can do? Im looking at stock sized RPF1s with RS3s on there. Brake Fluid and Upgraded Pads. MAYBE a lightwieght battery? not sure about that because ive heard that pushes you to STX.
scottynoshotty is offline   Reply With Quote
Old 02-25-2013, 10:53 PM   #2
ayau
Drives: Some rust bucket
tires
same width/diameter tires. offset can be +/- 6mm
front sway bar
dampers only (must keep OEM springs)
Old 02-25-2013, 11:05 PM   #3
scottynoshotty
Thanks..just ran into some 9 lb Enkei rims..1600 for a set of four in stock size but 44 lbs of rotating mass? HELLO
http://www.tirerack.com/wheels/Wheel...ll&sort=Weight
anyone know anything about these? ive been looking for a good light set of wheels and coming from a name like Enkei i figured theyd be pretty good quality..just surprised Ive never heard of them around here before. Certainly not cheap but like I said 44lbs of unsprung and rotating mass? Holy Toledo
Old 02-25-2013, 11:08 PM   #4
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
I've got Enkei's that are right to limit on offset. You can do dampers... and I've got one set of Koni sports in stock yet too. You can do one swaybar change.... and you want a bit more, but not too much front bar. Pads are legal to change, camber bolts (OEM only). Tires, well that's TBD about what's quickest.
Sam Strano is offline   Reply With Quote
Old 02-25-2013, 11:09 PM   #5
ayau
That's a typo. The best bang/buck is the Enkei RPF1.
Old 02-25-2013, 11:10 PM   #6
Sam Strano
Sam Strano's Avatar
9 pounds? Not correct. RPF1's are just under 16 and you don't get much lighter....
Old 02-26-2013, 09:48 AM   #7
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Originally Posted by ayau View Post
tires
same width/diameter wheels. offset can be +/- 6mm
front sway bar (or rear, but as noted by Sam, you want a front for the 86)
OEM front strut alignment bolts
any exhaust behind the 2nd cat
drop in air filter
lots of info on here regarding the alignment bolts, etc
e.g. http://www.ft86club.com/forums/showt...ighlight=stock
or
Also, here's a handy chart that compares allowed modifications across categories:
http://www.sff.net/people/dburkhead/prepcompare.htm
jdrxb9 is offline   Reply With Quote
Old 02-26-2013, 11:46 AM   #8
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
BFGoodrich Rivals in 225/45-17 on Kosei K4R 17x7, Konis, camber bolts, adjustable front sway bar, alignment maxing out negative front camber. BOOM.
enjoyminutemaid is offline   Reply With Quote
Old 02-26-2013, 01:11 PM   #9
colHolm
Default User Title
colHolm's Avatar
Enkei's website lists these at ~16 lbs
colHolm is offline   Reply With Quote
Old 02-26-2013, 01:36 PM   #10
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
You can't use those for RTR anyways. They are a 17x8 and you can't use 18's
You have to stick to a 17x7 rim and you have 6mm of offset you can go.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 02-26-2013, 04:37 PM   #11
fredk
Drives: FFR Cobra, RF'93 FB, 95 Miata, FR-S
RPF/1's weigh 4lbs a corner less than my stock wheels and tires, and that's with 235/40 Z2's. I was also surprised to see that my car weighed 2680 with 3/4 tank of gas.
Sam? What happened to the not giving all the info away???
fredk is offline   Reply With Quote
Old 02-26-2013, 04:59 PM   #12
RandyP
Drives: Asphalt FRS
Kosei K4R are only 14 lbs and you can use a spacer if you want to max out the track width.
RandyP is offline   Reply With Quote
Old 02-26-2013, 07:22 PM   #13
autoXracer
Drives: 2013 WRB BRZ
Is this true? I have only seen tirerack listing it as 14 lb. If so it's even lighter than Enkei RPF1 and cheaper.
autoXracer is offline   Reply With Quote
Old 02-26-2013, 07:25 PM   #14
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Yeah, that weight should be correct for the Koseis. I have the Kosei K1 TS on my BRZ, which are the same size and offset as the K4R, but weigh 14.6 lbs, for some reason Tirerack doesn't list them for the BRZ. I originally had them on my Forester XT.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
KW V3 Setup for Street use. Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 09-03-2016 02:48 AM
Optimal Wheel Size for Stock Power Tanuki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 110 06-09-2016 10:08 PM
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 12:40 AM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Optimal tint (California mostly) Oriental Life Southern California 49 08-17-2012 07:05 PM
