Old 06-01-2015, 02:41 AM   #1
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
All my 1/2j swaps
For those who went with Exessive motor mounts, any issues for the vvti ?
PolishFrs13 is offline   Reply With Quote
Old 06-01-2015, 09:56 PM   #2
Kwoodrow3
Drives: SRT4
They say that those mounts don't work with the VVTI blocks with only the forward mount locations. I have a non-VVTI and they work fine but I'm unsure if the VVTI blocks have multiple mounting locations?
Kwoodrow3 is offline   Reply With Quote
Old 06-02-2015, 01:27 PM   #3
Ross
Drives: 85 corolla gts
used a non vvt setup, could run into hood clearance issues possibly.
Ross is offline   Reply With Quote
Old 06-02-2015, 05:30 PM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Why does your subject line have nothing to do with your post?
Old 06-02-2015, 05:34 PM   #5
PolishFrs13
building life
Because it's only for those who have done a 1j or 2j swap using those mounts
Old 06-02-2015, 05:34 PM   #6
PolishFrs13
building life
Yeah I'm going to for a non vvti motor to be safe
Old 06-03-2015, 09:15 AM   #7
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I have the Xcessive mounts in my build ( @Ross is building my car). They're made sturdy, fit well, and are cheap.
The difference is in the heads. The non-VVTi blocks had an additional mounting point for the engine mounts further aft than the VVTi blocks... so as long as you have a non-VVTi short block, you should be good to go.
With that said... the amount of custom fabrication this build requires, it would be more cost beneficial to just make your own mounts to suit your needs since every build is different. Mine has full accessories, I think I'm the only one with that setup.
tl;dr - VVTi head, non-VVTi short block with these mounts should work no problem.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 06-03-2015, 10:17 AM   #8
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
This subject line "All my 1/2j swaps," does not mean, "only for those who have done a 1j or 2j swap using those mounts "
Your subject line implies, "here are pictures or stories about all of the 1j and 2j swaps I have done"
Old 06-03-2015, 01:56 PM   #9
53Driver
T64-416Ax3=13,140shp
53Driver's Avatar
Drives: 2002 AP1 and 2015 F-150 EB (DD)
Yeah man, that's how I read it. I came in here expecting a bunch of cool pics and stories, leave disappoint.
53Driver is offline   Reply With Quote
Old 06-03-2015, 04:54 PM   #10
Silvermk2
Drives: Toyota Supra 2JZGTE VVTi
The 2JZ VVTI motors should have both old and new mounting points on them. If you want VVTI just buy the whole VVTI motor and make your life easier. The newer blocks have the larger oil port for the VVTI oil line. You will need to get creative if you try and do this on the older block castings.
I've had both motors now in my Supra. HTH
Silvermk2 is offline   Reply With Quote
Old 06-03-2015, 08:57 PM   #11
rh9
Drives: red brz
I have a vvti 2jz .. Its 100% the same as the non vvti motors.. Has 6 holes for the engine mounts same as the non vvti blocks.. I have made my own nounts on my brz though ��
rh9 is offline   Reply With Quote
Old 06-10-2015, 03:47 AM   #12
killercl0wnfish
Drives: fr-s
I made my own useing drift motion supra engine mounts then made the mount to bolt it to.. super easy and way cheaper with higher quality bushings
killercl0wnfish is offline   Reply With Quote
Steering wheel swaps Trashed675 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-07-2014 07:43 PM
Question about trunk swaps MooseWRX Cosmetic Modification (Interior/Exterior/Lighting) 4 12-13-2013 09:17 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
Engine Swaps Available 88blacktop Scion FR-S / Toyota 86 GT86 General Forum 2 05-04-2012 06:45 PM
The AS1 and engine swaps Syldrin Engine, Exhaust, Transmission 36 01-25-2012 10:45 AM
