| CANADA Canada |
Drives: Subaru BRZ
OEM Alarm System
The factory alarm system I know on the BRZ does not come activated - I am not sure if this is the same thing on the FRS.
Essentially without programming it someone could smash your window unlock the door and get inside with no alarm going off at all! I know this applies to 2015 models, I am unsure about 2014 and 2013 but worth checking out.. Thought this may help some people out, no idea if it has been already discussed on the forum or not.
Mr.Fujitsubo
Drives: 2018 STI
Interesting, so any insight if it's on or off for 2015 FRS?
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
Drives: Subaru BRZ
To be honest I am not sure! If you follow the setup it'll say AL on or AL off.
Or just open your window lock the car and then reach in unlock manually and open the door - see if your alarm goes off. |
Drive From Home
Drives: BRZ STI Performance
I don't think the standard FRS comes with the alarm system, it is only available on the BRZ Limited and yes it is deactivated by default.
Once activated, if you try to open the door or trunk with the physical key, the alarm will go off (found this out when I gave the remote fob to the parking attendant at TD Tower and then proceed to open the door with my physical key cuz I forgot something). |
Drives: Toyota gt86 my19
Hi
The last toyobaru have factory alarm? Thanks |
Drives: Car
Can anyone clarify the steps? What they mean by Lock the doors using "Remove Keyless" access function? I assume 2 is using the Lock button on the Fob...what about #3?
Also, is it off by default on MY2017's? |
Drives: 2016 Halo FRS
I think the part about enabling the alarm to function (opposed to turning on/off) is on the bottom right side of the page. The part that details holding down the window switch.
| Need an Alarm System! | Captain.K | Southern California | 5 | 04-18-2015 02:59 AM |
| FR-S alarm system | Derrickchai39 | Scion FR-S / Toyota 86 GT86 General Forum | 62 | 06-02-2014 11:07 AM |
| Alarm system for the 86 | Speedoponic | Electronics | Audio | NAV | Infotainment | 14 | 01-13-2014 01:13 AM |
| Best alarm system? | normanb21 | Electronics | Audio | NAV | Infotainment | 0 | 05-08-2013 06:25 PM |
| Alarm System | Dan86 | Issues | Warranty | Recalls / TSB | 3 | 09-06-2012 02:06 PM |
