Old 05-24-2015, 09:53 PM   #1
Jayce
Drives: Scion Fr-s
Buddy Tail Lights
Hey guys I just installed the buddy light taillights on my brothers brz (automatic) I turned it on and it works, the only problem is that it won't shift out of park, and the turn signals won't work. Can anyone help on what to do?
I checked the fuse and everything.
Jayce is offline   Reply With Quote
Old 05-24-2015, 10:33 PM   #2
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
how about checking the led relay or re-using the factory turn
signal relay and check the wiring in the rear tail assembly?
possibly put everything back together since it only takes 5-10 minutes.. and make
sure it works that way then go back into putting the buddyclub tails again... and relay
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 05-24-2015, 10:55 PM   #3
Jayce
Drives: Scion Fr-s
Hey man thanks for the advice but I dont know if its the wiring, I put back the stock flasher and now the car wont turn on O.O I just dont know what to do anymore
Old 05-24-2015, 11:01 PM   #4
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
did you check battery? is it cranking not cranking? light are on?
more info would be helpful.. did you re-install stock tails?
Flex Fuel Turbo BRZ
Old 05-24-2015, 11:04 PM   #5
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
i find it odd that your car does not start after installing tail lights..
maybe your battery dead cause u left light on or something while car is off?
try jump starting it.
Flex Fuel Turbo BRZ
Old 05-24-2015, 11:06 PM   #6
Jayce
Drives: Scion Fr-s
When I press the push button it cranks but it wont turn on. I checked the battery it was fine.
Old 05-24-2015, 11:09 PM   #7
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
i would advise to re-check everything you disconnected and re-tighten what you removed. possibly dead battery did you try to jump start?...
Flex Fuel Turbo BRZ
Old 05-24-2015, 11:31 PM   #8
Jayce
Drives: Scion Fr-s
Ima try to jump start it tomorrow
Old 05-24-2015, 11:32 PM   #9
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
okay good luck pm me if you have more questions.. maybe take pictures of what u did...
Flex Fuel Turbo BRZ
Buddy Club Tail Lights Hyperblinking Itssrayyxd Scion FR-S / Toyota 86 GT86 General Forum 5 02-06-2015 12:22 AM
wtb some amber buddy club tail lights Vincenttam Want-To-Buy Requests 0 01-03-2015 08:17 PM
FS: *BRAND NEW* Buddy Club Tail Lights CanibeatNoel Exterior Parts (Aero, Lighting, Etc.) 3 08-27-2014 05:32 AM
Buddy Club Tail Lights Zero90 Cosmetic Modification (Interior/Exterior/Lighting) 37 02-27-2014 12:13 AM
