Old 02-05-2015, 04:07 PM   #1
Itssrayyxd
Drives: Scion frs.
Buddy Club Tail Lights Hyperblinking
I just got a used set of BC tail lights that is hyperblinking. How do I get this fixed? I read that you can get a flasher relay but I only saw posts for relays for switchback turn signals. Would these relays work for tail lights as well?
Itssrayyxd is offline   Reply With Quote
Old 02-05-2015, 04:25 PM   #2
jonzhuxD
Drives: Ultramarine FR-S
The relays for the switchback turn signals are exactly the same as the relay for any LED turn signals. You could acquire one of these relays or wire in resistors in your turn signal circuit to fix the hyperblinking. The relay is easy to replace, there's a DIY floating around on the forums on how to replace it.
jonzhuxD is offline   Reply With Quote
Old 02-05-2015, 04:29 PM   #3
Bergen23
Drives: '15 Halo FR-S
As mentioned, you will need the relay, and the DIY is easier than swapping out your tails.
Edit: Just an FYI, the lights in the tails are LEDs, so yes, a LED relay will work for them. It is necessary since they draw less power than an incandescent so your car will think the lights are out.
Bergen23 is offline   Reply With Quote
Old 02-05-2015, 06:40 PM   #4
Itssrayyxd
Drives: Scion frs.
Is there a relay that's you'd recommend?
Old 02-05-2015, 08:00 PM   #5
axelo
Drives: Whiteout frs
Tapturn...get it with stobepack at www.autowindow.com
Now i find ordinary turn signaling boring and cheap...jejeje
axelo is offline   Reply With Quote
Old 02-06-2015, 12:22 AM   #6
jonzhuxD
Any LED relay should work, you can search for subaru 8 pin LED relay and pretty much any one that shows up will work. I have this one personally.
[ame="http://www.amazon.com/81980-50030-066500-4650-Electronic-Flasher-Toyota/dp/B008C9YS0Y#customerReviews"]Amazon.com: 8-Pin 81980-50030 066500-4650 Electronic LED Flasher Assy Relay Fix For Lexus Scion or Toyota LED Turn Signal Light Bulbs: Automotive[/ame]
The tap turn relay is definitely cool though, and hand built by the seller, I'd check it out if you can justify it.
The Following 2 Users Say Thank You to jonzhuxD For This Useful Post:
Sugi (02-26-2016), tumbla.jr (04-22-2015)
FS: Buddy Club Tail Lights *USDM* Like New/Used CanibeatNoel Exterior Parts (Aero, Lighting, Etc.) 3 01-20-2015 08:04 AM
wtb some amber buddy club tail lights Vincenttam Want-To-Buy Requests 0 01-03-2015 08:17 PM
FS: *BRAND NEW* Buddy Club Tail Lights CanibeatNoel Exterior Parts (Aero, Lighting, Etc.) 3 08-27-2014 05:32 AM
Buddy Club Tail Lights Zero90 Cosmetic Modification (Interior/Exterior/Lighting) 37 02-27-2014 12:13 AM
