Old 05-22-2015, 09:23 PM   #1
thatotheritguy
Drives: '13 BRZ Limited
Ice Chests That Fit In Trunk
This is a bit of an odd one: I end up doing quite a large amount of road trips (30k miles and only had it a year and a half) and I have had an issue finding a hard sided ice chest that fits in my trunk to keep my various beverages cold, and does not throw water everywhere. I was just curious what y'all were using.
I have a big one (igloo Yukon) for my larger/camping/race track weekend needs, I just need a small one for the day tripping.
Cheers!
thatotheritguy is offline   Reply With Quote
Old 05-22-2015, 10:16 PM   #2
gravitylover
Why not just go soft sided with ice packs? Solves the splash problem and you can keep it in the back seat so those beverages are more easily accessible.
Old 05-22-2015, 10:26 PM   #3
Gunman
Drives: 2019 Mazda Miata RF
I have one of these. It fits, but it has to sit in the middle of the trunk, and the handle nearly touches the top. I put a towel on it, if I'm going on a spirited drive.
http://www.igloocoolers.com/Coolers/...MaxCold-30-Can
Gunman is offline   Reply With Quote
The Following User Says Thank You to Gunman For This Useful Post:
hmong337 (05-22-2015)
Old 05-23-2015, 12:16 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
Its not very big but fits perfectly for my track days.
You can see it fits well with tools. On right side.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Choco (05-23-2015)
Old 05-23-2015, 09:51 AM   #5
thatotheritguy
I have not considered the cold packs before. My only concerns with those is having to refreeze them for the return journey that and the Texas heat. But that is still something to add to my list of things to consider.
Old 05-23-2015, 10:00 AM   #6
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
I have one of these stackable coleman ones and should fit with no problems.
http://www.coleman.com/product/24-ca...0#.VWCHBE_Bx8E
$15 [ame="http://www.amazon.com/Coleman-25-Quart-Party-Stacker-Cooler/dp/B00363PSBE"]Coleman 25-Quart Party Stacker Cooler, Blue | Amazon.com: Outdoor Recreation[/ame]
I have seen them recently at Target or Walmart and should allow you to put some things on top of it.
I'll try to snap a pic of it in the car later today.
Aozora.BRZ is offline   Reply With Quote
The Following User Says Thank You to Aozora.BRZ For This Useful Post:
Imrac (05-24-2015)
Old 05-23-2015, 10:23 AM   #7
thatotheritguy
That looks perfect.
Old 05-23-2015, 12:37 PM   #8
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Stupid Coleman doesn't make any short Xtreme coolers
That flat stackable cooler is nifty and cheap, and based on your last reply, it may be suitable for your needs (though you mentioned Texas heat).
Personally, I wanted something:
  • More insulated (even up here in relatively temperate Massachusetts)
  • Tall enough to hold 1 liter refillable bottles upright
I went with a [ame="http://www.amazon.com/Polar-Bear-Coolers-Pack-Cooler/dp/B003KU02KU"]Polar Bear 12[/ame].
It wasn't cheap ($44), but is easy to pack and carry, easily fits in the FT86 trunk (along with other gear), and is rated to keep ice in 100 degree temps for 24 hours (and food hot up to 200 degrees for hours).
Deslock is offline   Reply With Quote
The Following User Says Thank You to Deslock For This Useful Post:
Choco (05-23-2015)
Old 05-24-2015, 10:17 AM   #9
Imrac
Drives: 13 SWP BRZ Prem
+1 for the Colmen Stackable. I have one, fits great.
http://www.homedepot.com/p/Coleman-2...B&gclsrc=aw.ds
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 06-15-2015, 07:08 AM   #10
notout86
Drives: GTS 86 auto
I always pull everything out down to the metal and line the floor with foil to insulate against all radiant heat from below (road and exhaust system) heat etc. Even better with a thin layer of anything non conductive under the foil. Combined with a white car and cold things wrapped in a blanket I find it remarkable how long they stay cold.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 09:36 PM
Zeta & Carsmo Armrest, Weathertech front and trunk mats, OEM scion trunk carpet HighbreadEH3 Interior Parts (Incl. Lighting) 16 07-29-2013 10:42 AM
Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) Iamthebatman Exterior Parts (Aero, Lighting, Etc.) 2 07-18-2013 02:12 PM
WTT Raven FRS wingless trunk for your Black BRZ limited spoiler trunk Tylub Exterior Parts (Aero, Lighting, Etc.) 0 05-12-2013 08:21 PM
