Old 05-22-2015, 12:20 AM   #1
TJ213
Drives:
Gaskets for used TRD exhaust
I Just bought a used TRD exhaust from another forum member and have been trying to figure out what gaskets I need. Looking at the exhaust diagram it appears I need two gaskets, one from the front pipe to the mid pipe, and one from the mid pipe to the muffler.
Looking through the install it looks like the front to mid pipe gasket might be this:
http://www.ft86speedfactory.com/suba...sket-1100.html
But I haven't had any luck with the mid to muffler. There is a part number 44022AA122 but I haven't been able to find a scion part under that number?
If I can find that second part, am I good gasket wise? Sorry for the noob question, this is the first car I've modified in any way. I've been reading around, but haven't been able to pin down exactly what I need for this install.
TJ213 is offline   Reply With Quote
Old 05-22-2015, 11:39 AM   #2
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
The front pipe to midpipe is a donut gasket.
The rest are regular gaskets that use 2 bolts. You can buy OEM, or you can buy the Grimmspeed ones which are a bit more expensive, but supposedly reusable and less flimsy.
Jyn is offline   Reply With Quote
Old 05-22-2015, 04:08 PM   #3
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Picture taken from this thread.
The gasket between the front pipe and the cat back pipe is that one. Black doughnut shape one. If you remove the original cat back pipe, that black gasket stays on the front pipe. You just use that as is. You don't need to put the gasket you linked in your post.
Sigh-on-Rice is offline   Reply With Quote
Old 05-22-2015, 08:28 PM   #4
DAEMANO
Time Traveller
You probably need this thing...
http://www.suprastore.com/trdexhakit.html
Old 09-29-2015, 06:22 PM   #5
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Sorry to resurrect, will a new OEM midpipe to muffler gasket fit? I ask because the stock is two bolts, the TRD is three bolts.
V_86 is offline   Reply With Quote
Old 04-01-2016, 11:41 PM   #6
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Back from the dead. Anyone know where to get the gasket from the midpipe to axleback?
Decimus is offline   Reply With Quote
Old 04-01-2016, 11:48 PM   #7
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Subaru oem parts; toyota oem parts; rallysport direct, ft86speedfactor; grimmspeed
These all should have what you need to name a few
MS, CSCS, TSAC-F, CPT
Old 06-03-2016, 02:48 AM   #8
zunairgt86
Drives: Black FR-S
Did anyone find out where to get gasket for TRD quad tip exhaust? It requires 3 bolts and is different than OEM exhaust. It's the gasket connecting midpipe to muffler..
zunairgt86 is offline   Reply With Quote
j2 exhaust gaskets replacement? bakerr6 Engine, Exhaust, Transmission 11 02-19-2015 05:19 AM
Exhaust and header gaskets Cu0ngsayz Want-To-Buy Requests 4 10-22-2014 12:47 AM
store that sells exhaust gaskets DarkestBuddha Southern California 3 08-08-2014 02:41 AM
GrimmSpeed BRZ/FR-S Exhaust Gaskets - Now Available! GrimmSpeed Engine, Exhaust, Bolt-Ons 2 01-19-2014 10:04 PM
Exhaust Gaskets Trashed675 Engine, Exhaust, Transmission 4 11-19-2013 07:43 PM
