Old 05-18-2015, 05:58 PM   #1
Vroomin86
Drives: 2015 Fire
Traction control kicking in on front ?
Something weird is happening. This happened after installing my wheels. I'll give as much info as I can to see if anyone can help me identify the issues.
Wheels: 18x9+35 squared.
Tires: 245/40/18 and 265/35/18 in the rear.
The issue: At high speed turns.......
example: a round-about exit off a highway or on-ramp. Let's say I am traveling about 65 or 70mph and I go turn into the turn. It's not like a crazy sharp turn where I should the trac control to go off. I am talking about a turn that makes the steering wheel barely move. the moment my steering wheel travels even just a quarter of the way all of a sudden the traction control lights up, and the car makes a really weird mechanism. Almost like the outer most front wheels' ABS kicks in.. What gives?
Btw it happened on stock suspension and its happening on Coilovers. Never happened on stock wheels even at 100mph.
Vroomin86 is offline   Reply With Quote
Old 05-18-2015, 06:05 PM   #2
juliog
juliog's Avatar
Drives: 86
Why are you running staggered tires on square wheels? Different effective tire diameter front and rear will confuse the car.
juliog is offline   Reply With Quote
Old 05-18-2015, 06:09 PM   #3
Vroomin86
Drives: 2015 Fire
I am pretty sure as long as I stay within rolling diameter that shouldn't be the case but please do explain it a bit. I am not here to deny advice. I simply can't stand not being able to drive my car spirited through any turn.
Old 05-18-2015, 06:12 PM   #4
juliog
juliog's Avatar
Drives: 86
What's the brand/model of the tires? Not every 245 or 265 tire is the same width, actual width and therefore rolling diameter will vary. Did you check for even tire pressures?
OEM rolling diameter is 24.7". Your combo would be about 25.7" F (+4%) / 25.3" (+2.5%) R. That's quite a deviation.
Old 05-18-2015, 06:20 PM   #5
Vroomin86
Drives: 2015 Fire
Yea 35psi all around. The diameter between the two is .3 of an inch difference and revs/mile less than 15 ticks apart.
Old 05-18-2015, 06:26 PM   #6
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Did you see this thread
http://www.ft86club.com/forums/showthread.php?t=87138
sittinSideways is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 12:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Traction Control / Vehicle Stability VSC kicking in when not necessary? WTF Scion FR-S / Toyota 86 GT86 General Forum 15 08-15-2012 04:24 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
