Old 05-15-2015, 03:55 PM   #1
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Valenti Lamps OTHER THAN Tails and Headlamps
We import Valenti products directly from Valenti of Japan. I've seen a lot of posts about the tail lamps and headlamps, but not much mention of Valenti's other products for the 86 cars. I thought I'd share some photos.
Interior Lamp Kit
This kit includes LED panels for the dome lamp, trunk lamp, and rear license plate (tag) lamps.
That's the kit.
There's also an optional lens and reflector kit that you can add for the dome lamp. Since the original lens is designed for a halogen bulb, the Valenti lens/reflector combo help diffuse the LED light more evenly, and it looks better.
Lens/reflector option
To install the dome lamp, you pry the lens off the fixture using a little screwdriver. Remove the bulb and install the Valenti bulb adapter, then stick the LED panel in place. You can see it comes with some little foam blocks to support the flat panel.
Installation in progress
Install done (factory lens)
Looks good! You can see how the factory lens has provision for a type of bulb that's no longer there, though.
Here I removed the factory lens, and installed the Valenti reflector. I dialed down the exposure because otherwise it would just be a blaze of light.
Reflector installed (no lens)
Lens installed
The trunk lamp installs really easily.
Valenti LED trunk lamp before and after
The tag lights are a little bit more work. You have to remove the trunk lid liner, if you have one, and then get at the bulb housings from inside the trunk lid. Then you have to position the lamp units inside the housing, and get them stuck in place. It's kind of a ship-in-a-bottle operation. Once installed they look something like this:
Valenti tag lamps installed
Tag lamp on
Mach V Dan is offline   Reply With Quote
Old 05-15-2015, 03:56 PM   #2
Mach V Dan
Courtesy lamps
These are the little lights in the doors that light up the ground when the door is open, and help other cars see your door at night. The Valenti product is nicer/better than just a replacement LED bulb; it is a specificially-designed flat panel that fits in the stock lamp housing.
You just pry the lamp unit out, take it apart and insert the new panel, then plug the bulb base for the panel into the stock bulb socket.
Assembled
It's really bright!
Vanity lights
These are the bulbs in the sun visors. The stock ones are pretty weak and yellow. The Valenti units are sort of a hybrid bulb/circuit board.
Again, you just pry off the lens, pull out the old bulb. (Hot if it's been on for a while!) Then just press the new bulb assembly into the socket. Put the lens back on and you're done.
Side markers
Some of the aftermarket units function as a turn signal and require extra wiring. Some of them are molded badly and they tend to fall out. The Valenti is just a replacement lamp -- no additonal functions over stock -- but it's made very well and the fit is excellent.
The come in clear, amber, and smoke. Install is very easy. Take out the factory lamp housing, quarter turn to free it from the bulb socket, put the plug for the new lamp in the socket, and put it back together.
Smoke
Clear
Amber. (Sorry for not having my own photo of these.)
Clear on our white BRZ
They light up nice and bright, even the smoke ones.
I think that about covers it. The only thing I didn't go into is the Valenti center rear fog/backup light unit, but I'll get to that another time. Yes, we do stock and sell these items, on our web site, which is in my sig.
--Dan
Mach V
Old 05-15-2015, 03:58 PM   #3
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Interested in the full kit what's the price?
Also are you going to carry the visor lights
Old 05-15-2015, 04:26 PM   #4
Mach V Dan
Go to our web site (see my sig pic) for pricing. Full kit page is HERE. Yes, visor lights are in stock, HERE.
--Dan
Mach V
dome lamp, dome light, interior lights, tag lights, valenti
[GB] The 4th Valenti LED Tail Lamps Group Buy pansontw Groupbuys 247 09-27-2015 04:25 AM
Pansontw - Valenti LED Tail Lamps 93Targa User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-19-2014 08:08 AM
FS BRAND NEW VALENTI TAIL LAMPS.... 5AD86D Exterior Parts (Aero, Lighting, Etc.) 9 05-20-2014 05:49 PM
FS: Valenti LED Tail lights + LED Reverse Lamps donutfilling Exterior Parts (Aero, Lighting, Etc.) 6 03-27-2014 01:52 AM
