Old 05-12-2015, 07:37 PM   #1
Scuba86
Drives: 2014 FR-S Monogram Raven
Getting things to stick to the interior dash
Anyone had any luck with getting anything to stick for long periods of time on the interior dash pieces or pillars? Any 3m tape I use doesn't seem to stay on for long after it sits in the heat for a while.
Scuba86 is offline   Reply With Quote
The Following User Says Thank You to Scuba86 For This Useful Post:
Gunman (05-12-2015)
Old 05-12-2015, 07:42 PM   #2
Gunman
Drives: 2019 Mazda Miata RF
Interesting question, I was just considering using some velcro on the dash, to hold my phone. Looking forward to input.
Gunman is offline   Reply With Quote
Old 05-12-2015, 07:53 PM   #3
Fishbone
Drives: 2024 GR86
When the instrument panel is molded, top part that's soft, there is usually some oils or contamination that gets on it. Try using some IPA (rubbing alcohol) to clean the small spot you plan on sticking anything. Be careful not to get it on other areas because it might change the color slightly.
If not, get this. Its awesome. Rotates and fits perfect in our FRS because of radio location.
[ame="http://www.amazon.ca/Mountek-nGroove-Universal-Phones-Devices/dp/B004G1L52Q"]Mountek nGroove Grip Universal CD Slot Car Mount for Cell Phones and GPS Devices: Amazon.ca: Electronics[/ame]
Fishbone is offline   Reply With Quote
Old 05-12-2015, 07:57 PM   #4
swarb
silicone? not sure how that would react with the dash though.
Old 05-12-2015, 08:19 PM   #5
Fishbone
Drives: 2024 GR86
Sorry. Not sure I understand your question.
Old 05-14-2015, 12:58 AM   #6
Poodles
Drives: 2015 Series.Blue
Vinyl is a bit of a pain to stick stuff to. If you want it permanent, it's relatively easy, but something that is removable later is harder. The texture of the dash doesn't help either (and it's probably the issue you're having with the pillar).
Oh, and you shouldn't have ANYTHING attached to the pillar or the top of the passenger side dash as there's airbags there.
The Following User Says Thank You to Poodles For This Useful Post:
Chimera (05-14-2015)
Old 05-14-2015, 01:03 AM   #7
Chimera
Drives: FRS
I have 3m tape on 2 accessories in my interior with 0 issues, in atl. Not the hottest but certainly not cold.
WTT: 2013 FRS Interior Dash Panels for BRZ Silver dash panels DCStorm Interior Parts (Incl. Lighting) 10 03-27-2015 02:04 PM
How to remove the interior dash trim? liajet24 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-30-2013 01:34 PM
Good Vinyl for interior dash jybrd Cosmetic Modification (Interior/Exterior/Lighting) 3 07-09-2013 02:48 PM
All RED interior dash lights and hvac ? Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-05-2013 09:41 PM
Removing interior trim dash panels ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 7 05-30-2012 09:20 AM
