Drives: Argento FRS
How to remove the interior dash trim?
How do I remove the interior dash trim? The bezel around the stereo that extends off to above the glvoe compartment? Does anybody have a video of it being removed? or pictures?
Victim's aren't we all
Drives: Toyota GTS 86 - Pegasus White
Just place fingers under the plastic above the glove box and apply pressure and pull up and out. It will pop out and then you just move around the edge. It's quite easy. Then once that is done do the same to the radio surround work from the edge facing the glove box and move around the edge firm but slight pressure. It will pop out easy and off.
#3 | |
Drives: 2013 FR-S, 2012 MCS
Is there a video DIY on this that I just cant find? |
Drives: FR-S Series 10 #0059
It's as easy as Rumbaar describes, but if you want video, check out the OEM Audio Plus install guide (jump to about 1:41 in):
[ame]http://youtu.be/LytAyXbgS5w?t=1m41s[/ame] The passenger side dash panel removes in the same way as the head unit trim does. |
| Interior trim trim clips (Dash Trim Panel) | ubersoph | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 08-11-2022 07:47 AM |
| WTT: My FR-S black dash trim pieces for your BRZ silver dash trim pieces. | Tim_Asphalt_FRS | Interior Parts (Incl. Lighting) | 1 | 05-13-2013 06:25 PM |
| Leather wrapped interior pieces (including dash trim) pics | Gen | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 11-18-2012 03:08 PM |
| Possible CF dash trim panels, how to remove stock? | jm1681 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-11-2012 01:18 PM |
| Removing interior trim dash panels | ubersoph | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 05-30-2012 09:20 AM |
