Old 05-11-2015, 11:37 AM   #1
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Cold Tear?
I went to the track last weekend and I think I got some cold tearing. Is it safe to drive on the street? I have had the tires for less then 2 months.
kurbkilla is offline   Reply With Quote
Old 05-11-2015, 12:50 PM   #2
Normal chunking at the edges from overheating. More negative camber will fit that. If the tear doesn't go to the cord of the tire, you'll be just fine continuing to use them like normal.
Cheers, and props to you for enjoying your car at the track!
Old 05-11-2015, 01:16 PM   #3
kurbkilla
kurbkilla's Avatar
I have SPC Camber Bolts (-1.5º) do I need more? How can I tell if it went to the cord? could I do more track days with these tires or are the on street tires now?
Old 05-11-2015, 01:40 PM   #4
vroom4
You'll be fine. You ideally want around 3 degrees in the front.
vroom4 is offline   Reply With Quote
Old 05-11-2015, 02:28 PM   #5
you'll literally see wire on the tire. When you get really close, you can see it through the rubber (meaning u have less than 1mm rubber left). Keep an eye on the tire and use the tread depth indicators as a guide.
Your local tire shop should also be able to give you a free "paper" tire depth measuring ruler or doodad to help you out there.
Warning: Shoulder strap guide design weakness can tear seat Deslock BRZ First-Gen (2012+) — General Topics 56 04-21-2021 07:47 AM
FS Latherwerks Ti Tear Drop knob robtan Interior Parts (Incl. Lighting) 1 08-09-2014 06:59 PM
3M Clear Film - Tear Sirsimon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 03-25-2014 08:01 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Warning: Shoulder strap guide design weakness can tear seat Deslock Scion FR-S / Toyota 86 GT86 General Forum 3 04-27-2012 09:01 AM
