Old 05-08-2015, 01:09 AM   #1
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
Just install my new suspension
just install my Manzo suspension today, maybe u guys want to ask why u install a such a cheap suspension and i just want to say i got this for $400, ($900 for original price) brand new,why not, the almost same price for a set of springs.
just drive my car back home in I-10 in los angeles with hardest set up, i just want to say it is really stiff, uncomfortable, and in the afternoon i set it to most soft in my friends shop, i think it is a little better than OEM, but it is still not comfortable like some 4 doors car.
in the corner is so good, im really happy with a this suspension, although im just test it in the local, i will go to track in May 23rd in streets of willow, after that i will write some detail review about this suspension.
this suspension have a lot of function, front coilover can adjust camber even with OEM camber bolts a little bit, but i change bolts already, and it is 15 levels adjustment, it is really easy to install, fits perfect, but i think a adjustable end link is better, im already change to F&R Eibach sway bar.
A few question:
1: what should i set for track, this is 15 levels, i have to set front softer or rear softer?
2:right now all four wheels camber is about -2 degree with OEM control arms, is that enough?
BTW, plz rebuild road in Los Angeles, road quality is soooo bad.
plz forgive my poor english, im try my best to write this review, thanks.:bonk
the pic show the height between before&after install new suspension.
Thanks!~
ZHoward is offline   Reply With Quote
Old 05-08-2015, 02:28 PM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
2 degrees camber is a good range. When racing I would set the front more stiff than the rear. For the street I would also do front more stiff or set both front and rear to full soft.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
ZHoward (05-08-2015)
Old 05-08-2015, 02:45 PM   #3
ZHoward
ZHoward's Avatar
Full soft? Ru sure it will not scratch fender?
Old 05-08-2015, 03:46 PM   #4
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
you have a lot of clearance. you'll be fine
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 05-08-2015, 05:14 PM   #5
ZHoward
ZHoward's Avatar
Size:  209.5 KBdo u think it is a lot?😳 i think is too low😂
Old 05-08-2015, 05:45 PM   #6
8R6
8R6's Avatar
Drives: FRS
Attachment 109115do u think it is a lot?😳 i think is too low😂
that looks like only a 1" drop...
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Special_K (05-08-2015)
Old 05-08-2015, 06:53 PM   #7
Special_K
Bannéd
Special_K's Avatar
Drives: 2013 DGM BRZ
You have PLENTY of room to run full soft setup without any sort of rubbing.
Special_K is offline   Reply With Quote
Old 05-08-2015, 08:18 PM   #8
FRS Johnny
FRS Johnny's Avatar
Attachment 109115do u think it is a lot?�� i think is too low��
Yeah, you'll be fine. if you rub just camber it out. But from the looks you'll be fine. Are you rubbing already?
I have friends who go a lot lower and they are okay.
Old 05-09-2015, 02:42 AM   #9
ZHoward
ZHoward's Avatar
I just higher rear a little bit and it is fine now, west Los Angeles road is so bad
Old 05-09-2015, 02:49 AM   #10
HATED1
HATED1's Avatar
Drives: 86
Drop it this low.
HATED1 is offline   Reply With Quote
The Following User Says Thank You to HATED1 For This Useful Post:
ZHoward (05-09-2015)
Old 05-09-2015, 02:50 AM   #11
ZHoward
ZHoward's Avatar
Originally Posted by HATED1 View Post
Drop it this low.
Los Angeles road quality.....
Old 05-09-2015, 04:26 PM   #12
FRS Johnny
FRS Johnny's Avatar
Yeah LA roads suck, but its still do able. Just dodge the pot holes and know your roads and route, know where to exit places for the easiest driveway.
The Following User Says Thank You to FRS Johnny For This Useful Post:
DIY: Air Lift Suspension Install RallySport Direct DIY (Do-It-Yourself) Guides 63 04-16-2016 11:42 PM
Help w/ suspension install enjoyminutemaid NY / NJ / CT / PA 7 03-17-2013 08:51 PM
Help w/ Suspension Install enjoyminutemaid New England 0 03-17-2013 05:58 PM
BRZ suspension install pics VTR Performance Northwest 15 01-24-2013 02:23 AM
Suspension Install Pics Pete156 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-21-2013 07:11 PM
