Old 05-04-2015, 12:30 PM   #1
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
Stance LCA. WhiteLine links and arms noise
So I got BC coilovers and they were great! I then proceeded as for Stance LCA and WhiteLine end links and toe arms and after I installed them I made sure to torque everything to spec and double check how everything looks. But now I get this wear clunking clicking noise something like popcorn popping in a microwave and I can't seem to find where it's coming from. It's definitely the back. Does anyone know or have any ideas what it could be? It only happens at low speeds so I'm assuming something is hitting something elae
EightSix93 is offline   Reply With Quote
Old 05-04-2015, 01:13 PM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
How much are you dropped? Too low and it could be your axles.
Decay107 is offline   Reply With Quote
Old 05-04-2015, 01:33 PM   #3
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
A little under two inches. I think I know where it's coming. Either from the adjustable part of the LCA.
Old 05-05-2015, 02:46 AM   #4
norcalpb
norcalpb's Avatar
Probably your rear end links.
I've read somewhere that spherical end links that are a little heavier duty will squeak after a while. You can try re-greasing them but I heard it only helps for so long.
Old 05-06-2015, 04:11 PM   #5
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
It's your coilovers. BCs garbage is notorious for that crap.
Check the rear top hats and spring preload on the coilovers; I'm 99.999999% sure that's what it is.
TylerLieberman is offline   Reply With Quote
The Following User Says Thank You to TylerLieberman For This Useful Post:
8R6 (05-06-2015)
Old 05-06-2015, 06:11 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Axles click when they go bad.
Popcorn noises are usually a symptom of a loose top bolt on the strut, most likely on the pillowball. Check your top hats.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
8R6 (05-06-2015)
Old 05-06-2015, 07:44 PM   #7
8R6
8R6's Avatar
Drives: FRS
nut on the top hats
8R6 is offline   Reply With Quote
Old 05-06-2015, 07:47 PM   #8
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
-alex
The three nuts that connect the coilovers to your car right? Cause those are really tight
Old 05-06-2015, 07:49 PM   #9
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
Originally Posted by BRGT86 View Post
nut on the top hats
Are you talking about the one in the middle under the damping adjuster?
Old 05-06-2015, 07:50 PM   #10
8R6
8R6's Avatar
Drives: FRS
yeah
Old 05-06-2015, 07:51 PM   #11
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
yeah
Do you know the torque spec for it?
Old 05-06-2015, 07:52 PM   #12
8R6
8R6's Avatar
Drives: FRS
i cant remember exactly but i think it was something like 41 lb.-ft.
when you tighten it though, you have to make sure the shaft isnt spinning with the it.
The Following User Says Thank You to 8R6 For This Useful Post:
EightSix93 (05-06-2015)
■■ Stance Lower Control Arms & Stance Coilovers ■■ FREE SHIPPING - Photos and Video. FT-86 SpeedFactory Brakes, Suspension, Chassis 338 09-30-2016 03:46 PM
Stance USA Front Adjustable Sway bar Swaybar End Links - $100 shipped STS-V Brakes, Suspension, Chassis 3 08-31-2014 10:00 AM
whiteline adjustible rear end links driver01 Brakes, Suspension, Chassis 12 06-28-2014 09:13 AM
Stance super sport coilovers with front sway bar end links 900.00 kimchangil424 Brakes, Suspension, Chassis 4 02-06-2013 02:25 AM
Whiteline Sway Bar Links at Redline360 Redline360 Brakes, Suspension, Chassis 0 06-28-2012 10:44 PM
