Old 05-04-2015, 09:12 AM   #1
Drakelee117
Drives: Subaru BRZ 2015
Sticky on the front, loose on the back?
I love the the combination of responsiveness and stiffness the BRZ has. But I feel like it has a bit too much understeer in the corners. I am trying to adjust the issue by putting on some sway bars, how should I look into all the options? How does the stiffness compared to OEM contributes to the cornering characteristics? Also, if one bar is 100% stiffer than OEM, what does it mean for the ride? Right now I don't have to worry too much about pot holes and speed humps as long as I am within reasonable speed. What happens with the 100% or even more stiffness?
Drakelee117 is offline   Reply With Quote
Old 05-04-2015, 10:40 AM   #2
fika84
fika84's Avatar
What suspension do you have now? If all you want is more oversteer than just up the rear bar and leave the front alone for now.
fika84 is offline   Reply With Quote
Old 05-04-2015, 10:51 AM   #3
stevesnj
stevesnj's Avatar
Actually it sounds normal, these cars were designed and typically front planted rear less planted especially for track use. Sounds like you're braking too late going into the corners. just a thought
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
fika84 (05-04-2015)
Old 05-04-2015, 11:01 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm. On stock Primacies? Have thought about going other way around, eg. putting springs from FR-S? Though imho easiest/cheapest would be to play a bit with tyre pressure front/rear, and only then think about something to buy from aftermarket parts.
Old 05-04-2015, 11:04 AM   #5
Racecomp Engineering
Add some front camber to start.
- Andy
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
fika84 (05-04-2015), was385 (05-04-2015), wparsons (05-04-2015)
Old 05-04-2015, 11:57 AM   #6
fika84
fika84's Avatar
^ is a good suggestion to start! And where are you running into understeer? Are you on a track? Or canyon driving? I never have understeer unless I brake too late into a corner like @stevesnj suggested.
Old 05-04-2015, 12:09 PM   #7
gramicci101
Off Topic
Swaybars are for fine-tuning balance after you've done all the other things. Start with front camber, as Andy said (Camber bolts, $25). A decent performance alignment will do wonders.
Then consider tires. The OEM tires are ok, but they aren't great. It's easy to overdrive them, and if you ask more of them than they can give, you'll either get understeer or oversteer. They're great for learning because they're loud at the limit and they let go gradually, but regarding absolute traction, they're not that wonderful. A better tire will have better turn-in at better speeds.
Old 05-04-2015, 12:45 PM   #8
N234
N234's Avatar
Drives:
Good question is where is the understeer observed. Corner entry or exit? During throttle or braking?
The car is very neutral and you can probably correct this for cheap or free by purchasing camber bolts, or adjusting tire pressure and driver input.
Check pressure often and make the rear slightly higher than the front.
Turn in just before completely releasing the brakes, to keep the nose planted and the tail light.
N234 is offline   Reply With Quote
Old 05-04-2015, 12:50 PM   #9
fika84
fika84's Avatar
I definitely agree. I've personally NEVER had understeer on corner exit... but I could see how it could happen on some corners depending on elevation and geometry changes.
Old 05-04-2015, 01:26 PM   #10
Cope52
Drives: 2014 BRZ
If you are on the stock susp and street cornering the best thing to do is take OUT the camber. Get rear arms and set it to .4, leave the fronts as is. I noticed this in my old RX-8, the factory settings made it feel horrible in the corners, with lots of roll at the back.
Originally Posted by LeeMaster View Post
I cannot stress this enough, when I changed my rear differential fluid with Motul 300, my clutch engagement point felt smoother.
Cope52 is offline   Reply With Quote
Old 05-04-2015, 01:34 PM   #11
wparsons
wparsons's Avatar
The fronts have ~0*, which is horrible for any sort of spirited driving. By leaving the fronts and reducing rear camber you're reducing overall grip. By adding front camber (more negative) and leaving the rear alone you're adding overall grip.
As for understeer, it's easy to induce if you enter too hot, doesn't have to be under braking. Getting understeer on exit is a bit harder to induce, but can be done.
flickr
Old 05-04-2015, 02:35 PM   #12
Stiffer spring rate at the wheels = more load on that wheel. Stiffer front sways = more load on the front, and stiffer rear sways = more load on the rear.
When your load overcome's the tire's grip (ability to hold load), then the tire loses traction.
Start with your sways on full soft, and then if you still understeer, increase the rear sway by one setting. If you oversteer, increase the front sway by one setting.
Test at a safe environment; you don't want to be spinning out on the street if you get unexpected oversteer.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Gunman (05-05-2015), Koa (05-05-2015), sittinSideways (05-04-2015)
Old 05-04-2015, 03:22 PM   #13
was385
Drives: MT WRB BRZ Limited, 2007 911s
Go to the closest Subaru dealer and pick up the OEM Impreza crash bolts to dial in some more front camber (part #901000394). I think it's like $10-12 for the pair and pretty easily the best bang for the buck upgrade for a stock car.
was385 is offline   Reply With Quote
The Following 2 Users Say Thank You to was385 For This Useful Post:
Racecomp Engineering (05-04-2015), wparsons (05-05-2015)
Old 05-04-2015, 04:57 PM   #14
stevesnj
stevesnj's Avatar
Also you may just be into the throttle in the turn. Braking earlier and lightly in a corner let's momentum take you through the corner and then ease back into the throttle when you are just about out of the corner. Eventually you will start to learn when to brake later going into the turn and earlier accelerating out. I say work on this technique before putting out $$$$ you don't need to
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
8R6 (05-05-2015), N234 (05-04-2015)
FS: OEM FRONT PIPE & CAT BACK Privman Engine, Exhaust, Bolt-Ons 0 04-07-2015 07:39 PM
FS: OEM Cat Back & Front pipe Privman Wheels and Tires 0 04-07-2015 07:34 PM
Front end sounds loose Jamesbrz Issues | Warranty | Recalls / TSB 23 02-14-2014 08:28 AM
18x8.5 with 235x35 on all 4 corners OR 18x8 front + 18x9.5 back 235/35 + 255/35 back KSpider Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-14-2013 07:06 PM
FRont back up lights Subabie Cosmetic Modification (Interior/Exterior/Lighting) 15 03-08-2013 01:07 PM
