Old 03-08-2013, 08:33 AM   #1
Subabie
Drives: BRZ LTD
FRont back up lights
is there a way to convert the front LED to be use as day running light?
I just realize that lights only on when u shift reverse!
Subabie is offline   Reply With Quote
Old 03-08-2013, 08:37 AM   #2
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Are you talking about your front turn signals ? Because mine are white led and they are on all the time , just click the knob once just before the headlights and they will stay on and then when turning they will stay illuminated but blink brighter
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 03-08-2013, 08:44 AM   #3
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
He has a BRZ, so his lights are different than yours.
Perihelion is offline   Reply With Quote
Old 03-08-2013, 08:59 AM   #4
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
I have no idea what you are talking about. The LED strip above the fog lights are daytime running lights; they shut off when your head lights are on. There's the 'boomerang' lights in the headlight housing that act as parking lights (they are turn on in the 'parkling light' setting on the stalk or when the head lights are on.
There are no other LED lights in the front, and none that come on when you shift into reverse. Can you explain what you are talking about?
Grimlock is offline   Reply With Quote
Old 03-08-2013, 09:04 AM   #5
Subabie
Drives: BRZ LTD
Thanks for replying!! LoL .. i m so fecking noobie so bare with me ok
I got my brz last nite
in the front, there are
-headlight
-the strip light (right below it)
-and then fog linght (on bottom)
what i want to do is to have that middle lights (strip lights) to on everytime the car driven!!!
thanks in advance!!
Old 03-08-2013, 09:18 AM   #6
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
-headlight
thanks in advance!!
That strip you are talking about are the daytime running lights (DRL). They should be on any time the car is running and the headlights are not on.
In this picture the car is running, and the stalk is set to the 'parking lights' setting. Therefore the boomerang parking lights are on (and the headlights aren't). Also, the DRLs are on because the headlights are on.
I may be mistaken, but I think the DRLs also shut off when the ebrake is engaged. But they should always be on when driving and the headlights aren't on.
Old 03-08-2013, 09:42 AM   #7
Subabie
Drives: BRZ LTD
let me get this str8
if headlights on, that strips (not the boomerang) is OFF?
what i found out last nite was:
when i put car in reverse.. that strip turn on!!!
Old 03-08-2013, 10:20 AM   #8
Cameronghanson
Drives: n/a
If the headlights are off, it will turn on automatically when the parking break is off and car is shifted out of park (if you have an automatic)
Cameronghanson is offline   Reply With Quote
Old 03-08-2013, 10:20 AM   #9
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
That is correct.
That is weird. I have no idea what is going on, but if the headlights and ebrake are off (and the car is running), the LED strip should be on regardless of gear.
Old 03-08-2013, 10:21 AM   #10
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
This could be the missing info. I'm not sure how the automatics work but I suspect that in park the driving lights would shut themselves off.
Here's what I think now. The OP has an automatic and a garage. When he starts the car in the garage and puts the car in reverse, he sees the reflection of the DRLs off of the garage wall.
Old 03-08-2013, 10:27 AM   #11
Subabie
Drives: BRZ LTD
That is correct.
yes i have an AT
hmm .. i want it to be ON ... whenever the engine start .. dont b OFF when headlights ON, dont b ON when reverse ...
ON ... biatch ... LoL ....
Old 03-08-2013, 10:28 AM   #12
Cameronghanson
Drives: n/a
That's what I think too. It would look like the reverse lights turn on with front lights under those conditions!
Old 03-08-2013, 10:31 AM   #13
Cameronghanson
Drives: n/a
yes i have an AT
Yeah I've tried to wire them into headlights but not only are they insanely bright at night, the wiring is difficult. But this might help:
LED lights on when-
Engine must always be running
1. Headlights off (in position 1 or 2 not 3)
2. Car is not in park gear
3. Parking brake down
Old 03-08-2013, 10:57 AM   #14
DSOmegaX
DSOmegaX's Avatar
yes i have an AT
LED DRLs turn on when the handbrake is released and the car is in gear. That's why you're seeing them turn on when you shift into reverse. They remain on when you shift the car into D and will turn back OFF when you shift into park.
Yes, they turn OFF when the headlights are on. But considering how bright the LEDs are at night, you do not want them on. Otherwise you're just being a **** to the person in front of you. That's why you never see LEDs on with headlights for cars like Audi as well. You're LEDs work as intended. There's nothing wrong with them.
@dsomegax.cars
Who in Torrance can vinyl wrap the front lip, and tint my back lights? Liquidsnake Southern California 4 02-18-2013 08:54 PM
Front fog lights itisthumper DIY (Do-It-Yourself) Guides 28 11-03-2012 05:45 AM
HID front lights? frosty86 Cosmetic Modification (Interior/Exterior/Lighting) 8 10-25-2012 11:08 PM
Got my lights back from paint. Memphis Cosmetic Modification (Interior/Exterior/Lighting) 41 07-01-2012 10:45 AM
