Old 05-01-2015, 09:17 PM   #1
JS + BRZ
Drives: 2010 MS3
2013 BRZ Limited - Bluetooth connectivity issue
My BRZ and Note 4 have been problematic for awhile. Seems like it's connecting and disconnecting very randomly.
Is anyone having a similar issue? Any idea on how to fix this?
JS + BRZ is offline   Reply With Quote
Old 05-03-2015, 10:34 PM   #2
JS + BRZ
Drives: 2010 MS3
Am I the only one!?
Old 05-04-2015, 08:09 AM   #3
dinoniel
I used to have similiar issues with random disconnects. Try going into bluetooth settings on the headunit and deleting your phone then reconnecting. Used to work for me
dinoniel is offline   Reply With Quote
The Following User Says Thank You to dinoniel For This Useful Post:
JS + BRZ (05-04-2015)
Old 05-04-2015, 09:05 AM   #4
fika84
fika84's Avatar
Join the club. I gave up on it. I'll try again when I replace the HU with a Pioneer AVH-X5700BHS (hopefully this week). There are some things to try. You can change settings like whether the deck connects to the phone, or the phone connects to the deck. My HTC One (M7) would always disconnect after I received a text message..
There are LOTS of people that have had it though.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Old 05-04-2015, 05:41 PM   #5
JS + BRZ
Drives: 2010 MS3
Ah.. so it wasn't just me.
Man, is this really that difficult to figure it out? Come on Toyota/Subaru!
Old 05-04-2015, 09:01 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
It could be a phone issue.... My iPhone started doing it after I updated my iPhone last month....
Old 05-05-2015, 12:53 PM   #7
willypongtb
P MAI86
Drives: subaru brz limited
i start to have problem lately connect and disconnect galaxy note2
willypongtb is offline   Reply With Quote
Old 05-05-2015, 12:57 PM   #8
gramicci101
Off Topic
Mine will randomly lose the ability to select artists or tracks through the radio. I have to turn the phone's Bluetooth off and on again, and turn the radio off and on again, and then it works.
Old 05-05-2015, 01:18 PM   #9
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I think I found a fix for this, my Nexus 5 was connecting and disconnecting randomly for MONTHS until I tried this.
Start up the car and connect your phone.
Go to the "Phone" tab and a dialpad should show up. Underneath that there should be a tab marked "Settings"
Go in there and turn auto connect off. You'll have to turn your phone's bluetooth on every time you enter your car, but its better than the alternative.
Will post pics/DIY on request.
Bobblehead is offline   Reply With Quote
Old 05-05-2015, 01:32 PM   #10
fika84
fika84's Avatar
This is a good suggestion.. very possible that it's the auto connect that's causing all of the issues! How long has it been since you've had a connect/disconnect issue?
Old 05-05-2015, 01:38 PM   #11
Bobblehead
Bobblehead's Avatar
Its been fine ever since I turned off the auto connect! Its been about 3 days.
The Following User Says Thank You to Bobblehead For This Useful Post:
fika84 (05-05-2015)
Old 05-05-2015, 02:29 PM   #12
fika84
fika84's Avatar
I just tried this and within 10 minutes my phone had disconnected & reconnected.. Happened when my phone received an email.. I just turned off more things and I'll test it later. I turned off using the car as a headset (just music) and turned off the auto update phone book portion.. Let's see if this piece o crapola works as JUST a bluetooth music connection.
Old 05-05-2015, 02:56 PM   #13
lxsedan
Drives: 2013 BRZ SWP
No problems with my Iphone 4 when I had it, Iphone 5, Note 3 and Galaxy Nexus. All connect fine soon as I go into the car. '13 BRZ in Canada with the Pioneer HU
lxsedan is offline   Reply With Quote
Old 05-05-2015, 03:22 PM   #14
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
The autoconnect was the problem for me.
Go into the settings and disable it.
Load Bluetooth menu on phone and click on multimedia player or whatever your car is.
It will take a second to connect.
Done.
Takes about 10 seconds and has never fucked up once.
Jesse36m3 is offline   Reply With Quote
I've fixed my Bluetooth connection issue! Superhatch Issues | Warranty | Recalls / TSB 34 04-15-2015 02:15 AM
2013 BRZ Limited + Samsung Galaxy Note 2 Bluetooth issue JS + BRZ Issues | Warranty | Recalls / TSB 13 04-16-2014 04:41 PM
FRS iphone 5s bluetooth connection issue Gank61 Electronics | Audio | NAV | Infotainment 2 04-03-2014 09:19 AM
Please help! Bluetooth display issue! bdanisi Electronics | Audio | NAV | Infotainment 4 03-09-2013 10:27 AM
BRZ Limited Bluetooth Music issues blkwrxwag Electronics | Audio | NAV | Infotainment 14 12-13-2012 05:55 PM
