A man
Drives: 14 BRZed
*Thunk* and rattle in left front suspension
14 BRZ, 8K miles
Tein Monosport 8K/9K factory sway bar whiteline endlinks FR/RR ~2' front camber 17x9 RPF1 w/ 245/45/17 hotchkis front upper strut bar Ever since alignment, which just happened to coincide with endlink installation, I get a massive *THUNK* out of the drivers' side front when going over uneven road. It seems to happen when unloading suspension, but I can't be sure. No signs of contact/abrasion anywhere in the suspension. Sway bar and endlink appears to clear control-arm and shock body with room to spare. Re-torqued strut tower bolts, endlinks, spring perches, and verified that spring is slightly pre-loaded. I've had it up on alignment rack 3x and up on 4 stands in my garage probably 4-5x as well.. with wheels both loaded and unloaded. When I encounter lesser undulation on that side of the car, the sound that corner makes I can only liken to a spring rattling around a shock body. At this point, I'm thinking it's a defective strut (<3K miles on them), but there are no signs of oil anywhere either. Losing my mind. Has anyone here experienced something similar? Thanks |
A man
Drives: 14 BRZed
Turns out a friend had a similar issue with his Teins many years ago, and it turned out to be a failed/failing spherical bearing in the pillowball mount. Google-fu revealed that Tein is notorious for 1) not torquing the strut body nut to spec, and 2) prematurely failing spherical bearings. News to me.
In any case, I called Tein and they confirmed the symptoms sound like spherical bearing failure. I'll be disassembling the strut tomorrow to test. Either way, with less than 3K miles on the coilover, it's going back to Tein for analysis and service (under warranty). |
FYI I started getting a thunking noise on my new sway bars. Turned out I didn't grease the bushings properly. This doesn't quite sound like your situation but now someone knows. Good luck
| WTB: OEM Control Arms: Front Left & Back Left | norcalpb | Want-To-Buy Requests | 0 | 02-26-2015 08:55 PM |
| Left Door Rattle | Jigglybus | Electronics | Audio | NAV | Infotainment | 4 | 07-11-2014 11:35 AM |
| Need front left oem wrb fender | suboobaru | Southern California | 1 | 02-08-2014 11:38 PM |
| thunk when shifting into first | Skurj | BRZ First-Gen (2012+) — General Topics | 37 | 05-21-2013 04:48 PM |
| Rattle in rear left of car - Need some help! | eleu2166 | AUSTRALIA | 4 | 12-01-2012 09:51 AM |
