Old 04-29-2015, 09:09 PM   #1
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Will these fit? Gram Light 57xtreme sizes.
Im lowering the car an inch maybe more if I can get away with it. The wheels will be 18x9.5 Front and Rear. What size tire do I need to run to be ok at full lock? will 245/35/18 work or do I need 235/35/18? At the moment I dont want to roll my fenders and want as little negative camber as possible if thats what it takes to make the wheels/tires fit. Thanks for the help guys!
Jolt182 is offline   Reply With Quote
Old 04-29-2015, 09:11 PM   #2
Wilson15
Drives: Subaru BRZ Limited
what are you going to be lowered on?
Wilson15 is offline   Reply With Quote
Old 04-29-2015, 09:19 PM   #3
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Stance Coilovers
Old 04-29-2015, 10:08 PM   #4
Wilson15
18x9.5 will fit, tire size both those options will work, can go meatier if you want
The Following User Says Thank You to Wilson15 For This Useful Post:
Jolt182 (04-30-2015)
Old 04-30-2015, 10:20 PM   #5
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Thanks a bunch man
Gram Light 57xtreme Look-a-Like Alternatives soulstice Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 84 03-30-2015 11:54 PM
FS: Brand new Gram Light 57xtreme in Socal mtsui Wheels and Tires 57 12-12-2013 12:37 AM
Candy Red Gram Light 57Xtreme 18X9.5 +40 ugadogs_11 Wheels and Tires 8 10-03-2013 09:04 AM
FS: Gram Light 57Xtreme with Hankook V12 Evo clevrname Wheels and Tires 46 09-06-2013 04:24 PM
