Old 04-27-2015, 02:28 AM   #1
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
Just install Eibach anti-roll bar
Hi, guys, just bought a Eibach anti roll bar from our member for $250 which is i think is a good deal, and it is feels really good, but i still have a question:
what do u guys think stock shocks for track with swift spec t springs? is that enough for track? or i have to wait until i get money for BC coilover and springs?
Thanks!~
ZHoward is offline   Reply With Quote
Old 04-27-2015, 09:56 AM   #2
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Thanks!~
You can enjoy the the track regardless of your suspension. The first time I went to the track was in my Subaru and it was on stock springs and i still had a great time.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following 4 Users Say Thank You to Mr.Impreza For This Useful Post:
fika84 (04-27-2015), JS + BRZ (04-27-2015), strat61caster (04-27-2015), ZHoward (04-27-2015)
Old 04-27-2015, 01:57 PM   #3
strat61caster
strat61caster's Avatar
tl;dr the stock suspension is great as-is for track and autocross use, if it's your first time just go for it. In my opinion save the money on coilovers for getting brake pads for the track and better brake fluid as much as a $500 investment that is very much needed if you want to drive the car at >90% of it's capabilities.
The only thing you might want to do suspension wise before your first time to prepare for the track is a quality four wheel alignment, not a quicky place but a shop that actually specializes in fine tuning cars for the track/autocross.
From the factory the only thing that warrants improvement is front camber, typically it's less than -0.5 degrees, ideally for a true track car you want to be -2.0 degrees camber or more, this is not possible to do stock. The cheapest way to add camber is to get some "camber bolts" for the front end, this should get you to about -1.0 degree camber. This will help your front tires grip better and last longer on track for ~$20-40 for the bolts and $200-$300 for the alignment if I remember correctly. This should hold you over until you upgrade to whatever coilover system you decide with camber plates or some form of adjustability.
Save your money for brakes if you're serious about tracking.
At a minimum read everything given to you by the organization you will run with and read this:
http://www.ft86club.com/forums/showthread.php?t=25485
ineedyourdiddly
Old 04-27-2015, 02:08 PM   #4
JS + BRZ
Drives: 2010 MS3
Keep the stock suspension. Upgrade the brake pads and fluid. Get a helmet.
Use the leftover $$ for track days.
Enjoy that set up for like a year and upgrade next year.
JS + BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to JS + BRZ For This Useful Post:
Old 04-27-2015, 02:15 PM   #5
ZHoward
ZHoward's Avatar
Actually I'm already upgrade my brake, and I will get new wheels and Hankook RS3 next month, then I will do track after that, I will search camber bolts and do alignment, thanks a lot!
Eibach Anti-Roll Kit - Press Release FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-24-2017 04:55 AM
Eibach Anti-Roll Kit babykwiss Canada Classifieds 1 07-14-2014 09:29 AM
FS: Eibach Anti Roll Kit (From Pro-Plus Kit) Batman Brakes, Suspension, Chassis 1 03-31-2014 03:02 PM
**NEW EIBACH ANTI-ROLL KIT! SPECIAL PRICING!** genometuning Brakes, Suspension, Chassis 1 10-01-2012 01:07 PM
