Old 06-14-2012, 09:58 AM   #1
#87
I usually post drunk
#87's Avatar
Oil Change Questions
1. What is the part number for the subaru filter and crush washer?
2. What oil change quick valve is compatible with the oil pan?
3. Where can I get a hose that will fit the valve?
#87 is offline   Reply With Quote
Old 06-14-2012, 11:22 AM   #2
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
answer to #1
http://www.ft86club.com/forums/showp...3&postcount=42
hyper4mance is offline   Reply With Quote
Old 06-14-2012, 11:48 AM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
#2 is QuickOilDrainValve.com you want the 16mm one.
#3 is any auto parts store. Just show up with the valve and get a foot or two of transmission oil cooler hose or fuel hose that will fit. You can get heater hose, but it may deteriorate over time.
Old 06-16-2012, 11:36 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I prefer the F-108s, with he shorter nipple.
[ame="http://www.amazon.com/F108S-16mm-1-5-Fumoto-S-Type-Nipple/dp/B004FFHH0M/ref=sr_1_3?s=automotive&ie=UTF8&qid=1339904067&sr= 1-3&keywords=f-108s"] F108S(16mm-1.5): Fumoto S-Type Oil Drain Valve w/ Short Nipple Joint[/ame]
Old 06-17-2012, 12:51 AM   #5
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I ordered the F-105 from qwikvalve.com. I'm installing tomorrow. I'll do a DIY on how it works, install (unscrew, screw...duh).
Superhatch is offline   Reply With Quote
Old 06-17-2012, 02:08 AM   #6
Sportsguy83
Drives: Limited BRZ
Per this Post, it won't work. This is coming from Subaru part number for the drain plug.
http://www.ft86club.com/forums/showp...11&postcount=3
You need to get F-108, which is 16mm. F-105 is 20mm.
Old 06-17-2012, 02:22 AM   #7
Liquidsnake
Drives: "I drives like a Porsche"
If you guys have the scion two year service plan will they bitch if I take it in for an oil change before I hit my 5k miles?
Liquidsnake is offline   Reply With Quote
Old 06-17-2012, 10:45 AM   #8
flawedchemical
Drives: Silver 2013 FR-S
My guy at the Scion dealer told me they won't change it until 7500 miles in the fr-s and also that we only get 2 services no matter what!
I'm a little curious as to how this is going to turn out.
flawedchemical is offline   Reply With Quote
Old 06-17-2012, 10:49 AM   #9
Fly Guy
Fly Guy's Avatar
Drives: '91 MR2
7500 mile oil change intervals would make for 3 oil changes.
Tada-san: Oh so cooler than the concept.
Fly Guy is offline   Reply With Quote
Old 06-17-2012, 10:50 AM   #10
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
My dealer wouldn't do it early, but, I get mine at 5k and get 5 changes. Time for you to find a new dealer.
Old 06-17-2012, 12:39 PM   #11
Superhatch
AIM4APX
Superhatch's Avatar
For verification, the F-105 does not work. The company I purchased the valve from suggested the wrong part after I let them know I had a BRZ. Well, return time.
Oil change was easy, about 30m. My oil filter was on -really- tight though so I had to punch a small screwdriver into it to get it to turn as my strap wrench wouldn't fit in the space where the oil filter sits. Hopefully my new Subaru filter which I tightened will come of easier next time around.
Subaru suggests 3000m for the First oil change btw.
Old 06-17-2012, 12:52 PM   #12
Smokinbuffalo
BRZ Owner
Smokinbuffalo's Avatar
Drives: SWP Ltd MT BRZ, Scion xA
I changed my oil at 1010 miles. The filter was on tight. I Hastings usemy strap wrench to get it off.
The oil drains really quickly. It overwhelmed my catch pan.
The crush washer was not coming off the drain plug. I would of had to gouge the plug to remove the washer.
Buy the ticket, take the ride
Smokinbuffalo is offline   Reply With Quote
Old 06-17-2012, 01:22 PM   #13
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
mine slipped right off... it was just a flat black washer.
NeedsmoreCowbell is offline   Reply With Quote
Old 06-17-2012, 01:33 PM   #14
flawedchemical
Yea...I'm definitely gonna have to check into things.
And are you guys gonna change the washer every oil change?
Drifting Questions Shin Scion FR-S / Toyota 86 GT86 General Forum 56 05-30-2012 07:22 PM
Questions regarding FRS Pre-order ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 4 04-21-2012 02:42 PM
Questions about BRZ/FR-S @ NYIAS bimmerboy BRZ First-Gen (2012+) — General Topics 26 04-16-2012 10:55 PM
Couple of questions :P speedy07 BRZ First-Gen (2012+) — General Topics 25 02-17-2012 03:29 PM
Couple of questions :P speedy07 Scion FR-S / Toyota 86 GT86 General Forum 24 02-14-2012 08:23 PM
