| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
I usually post drunk
Oil Change Questions
1. What is the part number for the subaru filter and crush washer?
2. What oil change quick valve is compatible with the oil pan? 3. Where can I get a hose that will fit the valve? |
#2 |
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
#3 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
#2 is QuickOilDrainValve.com you want the 16mm one.
#3 is any auto parts store. Just show up with the valve and get a foot or two of transmission oil cooler hose or fuel hose that will fit. You can get heater hose, but it may deteriorate over time. |
#4 |
I Love custom Turbo kits
Drives: Limited BRZ
I prefer the F-108s, with he shorter nipple.
[ame="http://www.amazon.com/F108S-16mm-1-5-Fumoto-S-Type-Nipple/dp/B004FFHH0M/ref=sr_1_3?s=automotive&ie=UTF8&qid=1339904067&sr= 1-3&keywords=f-108s"] F108S(16mm-1.5): Fumoto S-Type Oil Drain Valve w/ Short Nipple Joint[/ame] |
#5 |
AIM4APX
Drives: 2013 WRB BRZ Limited
I ordered the F-105 from qwikvalve.com. I'm installing tomorrow. I'll do a DIY on how it works, install (unscrew, screw...duh).
#6 | |
Drives: Limited BRZ
http://www.ft86club.com/forums/showp...11&postcount=3 You need to get F-108, which is 16mm. F-105 is 20mm. |
#7 |
Drives: "I drives like a Porsche"
If you guys have the scion two year service plan will they bitch if I take it in for an oil change before I hit my 5k miles?
#8 |
Drives: Silver 2013 FR-S
My guy at the Scion dealer told me they won't change it until 7500 miles in the fr-s and also that we only get 2 services no matter what!
I'm a little curious as to how this is going to turn out. |
#9 |
Drives: '91 MR2
7500 mile oil change intervals would make for 3 oil changes.
Tada-san: Oh so cooler than the concept.
#10 |
That guy
Drives: Ultramarine mt FR-S
My dealer wouldn't do it early, but, I get mine at 5k and get 5 changes. Time for you to find a new dealer.
#11 |
AIM4APX
For verification, the F-105 does not work. The company I purchased the valve from suggested the wrong part after I let them know I had a BRZ. Well, return time.
Oil change was easy, about 30m. My oil filter was on -really- tight though so I had to punch a small screwdriver into it to get it to turn as my strap wrench wouldn't fit in the space where the oil filter sits. Hopefully my new Subaru filter which I tightened will come of easier next time around. Subaru suggests 3000m for the First oil change btw. |
#12 |
BRZ Owner
Drives: SWP Ltd MT BRZ, Scion xA
I changed my oil at 1010 miles. The filter was on tight. I Hastings usemy strap wrench to get it off.
The oil drains really quickly. It overwhelmed my catch pan. The crush washer was not coming off the drain plug. I would of had to gouge the plug to remove the washer.
Buy the ticket, take the ride
#13 |
toyotas are practical :)
Drives: Hot Lava FRS
#14 |
| Drifting Questions | Shin | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 05-30-2012 07:22 PM |
| Questions regarding FRS Pre-order | ft86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 04-21-2012 02:42 PM |
| Questions about BRZ/FR-S @ NYIAS | bimmerboy | BRZ First-Gen (2012+) — General Topics | 26 | 04-16-2012 10:55 PM |
| Couple of questions :P | speedy07 | BRZ First-Gen (2012+) — General Topics | 25 | 02-17-2012 03:29 PM |
| Couple of questions :P | speedy07 | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 02-14-2012 08:23 PM |
