Northern California NorCal
Old 04-18-2015, 12:04 PM   #1
ZOMBRZ
Drives: 2014 CBS BRZ Limited
HELP!!
So this problem started yesterday. My left signal (front, rear, and dash) will stay on. I can't signal right or put my hazards on. I think I may need a new flasher relay but I'm not sure. I have TOMS tails and the TOMS relay that was supplied with it.
If anyone has any input as to what I should do and/or if you have an extra relay, I am willing to buy and pick it up from wherever you are. Please help lol.
ZOMBRZ is offline   Reply With Quote
Old 04-18-2015, 12:05 PM   #2
ZOMBRZ
I've had the tails for about a year now. No other electrical mods besides switching out the side marker LEDs.
Old 04-18-2015, 08:13 PM   #3
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Could be a bad relay, i guess. Can you bypass the relay and see if it does the super speed blinking? That would tell you for sure.
Pwolf is offline   Reply With Quote
Old 04-18-2015, 11:12 PM   #4
ZOMBRZ
How do you bypass the relay? I unplugged the relay and tried to turn on my turn signal and flashers but nothing happened. No lights or anything. Just nothing at all.
Old 04-19-2015, 03:05 AM   #5
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
WTF happened to your OEM flasher?
CamryDS is offline   Reply With Quote
Old 04-19-2015, 11:50 AM   #6
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Leave the relay unplugged for 10 minutes and then put it back and try your flashers. If they still don't come on disconnect your battery for 10 minutes to reset your electronics. Have you installed leds for your front turns as well?
Old 04-20-2015, 11:32 AM   #7
sdlynx
sdlynx's Avatar
Drives: 2013 Scion FR-S - Firestorm
I had a problem with the flasher that came with my TOM's as well. I ended up purchasing a Tap Turn aftermarket flasher and haven't had problems since then. Added features as well. Not all that necessary, but, hey, it's worth mentioning....
http://www3.telus.net/s_mcphee/orderT.html
sdlynx is offline   Reply With Quote
Old 04-20-2015, 12:18 PM   #8
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Its a bad relay. I have the Toms also and the exact same thing happened to me. I didn't think of it much over the weekend then come to realize I have a dead battery the follow Monday morning .
Any similar LED flasher relay should work, try an auto parts store if you can't wait, should be a Toyota/Lexus part. I got this from Amazon because it was available on Prime and haven't had a problem since.
[ame="http://www.amazon.com/gp/product/B00B9H61BK/ref=oh_aui_search_detailpage?ie=UTF8&psc=1"]Amazon.com: 8-Pin Flashing Speed Adjustable Electronic LED Flasher Assy Relay Fix For Lexus Scion Toyota LED Turn Signal Light Bulbs: Automotive[/ame]
(@Pwolf remember when my turn signal would stay on at the end of that drive we did at Mt. Tam? )
Old 04-20-2015, 12:32 PM   #9
Pwolf
Pwolf's Avatar
Oh, I have video of it :P
Old 04-21-2015, 02:41 AM   #10
ZOMBRZ
Thanks everyone for your input. I unplugged the relay for 15 mins or so and plugged it back in. I haven't had a problem since but I did order the relay that @BigFatFlip recommended. I'm also considering the tapturn relay too. Is it pretty convenient to have? Or could I seriously do without?
Old 04-21-2015, 11:24 AM   #11
BigFatFlip
BigFatFlip's Avatar
I considered the TapTurn when looking, but thought of it as just something "nice to have". I just needed something to get back on the road, and didn't find anything at the autoparts store, which is why I just went with my suggestion.
Old 06-11-2015, 12:44 AM   #12
tdoggy57
tdoggy57's Avatar
Drives: Asphalt Scion FR-S
So if Im looking to install TOMS tails that I just bought used (no relay included), would this relay work? I was going to buy Tapturn but they have long shipping dates and Id like to install the tails ASAP.
Let me know if you have any recommendations!
tdoggy57 is offline   Reply With Quote
Old 06-11-2015, 12:51 AM   #13
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Any relay should work fine 👍🏻
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
tdoggy57 (06-11-2015)
Old 06-11-2015, 01:21 AM   #14
BigFatFlip
BigFatFlip's Avatar
^What he said. Pretty much any Toyota LED flasher relay should work, just make sure its compatible with the FRS/BRZ. I have the one I've linked for a couple of years now without any issue.
The Following User Says Thank You to BigFatFlip For This Useful Post:
