Drives: 2014 Subaru BRZ Limited 6MT
Transmission grind from 3rd-4th, remove mods before bringing to dealer?
So I've noticed for a while now that I have a grind from 3rd to 4th when shifting at high RPM's. I noticed that a lot of other people have had this same issue. My question is, currently I have the Perrin Shifter bushing, Whiteline Transmission bushing, and Mtec shifter springs installed. Do you guys think I need to remove all of these mods before bringing in the car to the dealer? I'm guessing so, but I wanted to ask before I spend the time/money to do so.
Drives: 2013 FRS- Hot Lava
Bushings:yes. I doubt anyone would notice the Mtec springs unless they go specifically searching for it (and have an OE piece for comparison).
Drives: 2013 Firestorm FRS
I probably would, for two reasons:
1. Dealer might complain 2. If dealer doesn't complain, but decides to swap/fix the trans, you might end up losing the parts since they most likely wont switch them over (especially the mtec springs). |
take 5 minutes to remove the whiteline tranny bushing insert following that dude's guide
leave the rest on and eat the cost.. I am not so sure they'd replace shifter bushings if it turns out to be your tranny. springs probably will be lost |
Okay, thanks guys. So someone wrote up a guide specifically on removing the tranny bushing? I'll have to search around for that.
edit: Nevermind, I found the "5 min" install guide. Looks simple enough... http://www.ft86club.com/forums/showthread.php?t=26411 |
Honestly I think I'm just going to remove the Perrin bushing as well, since it added a lot of NVH, mainly I suspect this whining sound when at low RPM's, which is annoying at highway speeds. Hopefully that isn't too much of a bitch to remove.
Troll Hunter
Drives: fr-s, tundra
let me know how it goes for you OP. I have the same grind but have been too lazy to bring it in.
Drives: 2013 MT Asphalt FRS
Man if it wasn't for all of us lazy fuckers, they probably would of recalled it by now!
#10 |
Son of a bitch... I completely forgot that I had the Perrin transmission support installed at the same time. Of course I didn't realize this until I was under the car, and had the bolt removed and the transmission jacked up a bit. It looked like too big of a job to tackle without a lift, so I'm just going to take it in to a shop to have them remove both at the same time. I was able to remove the shifter bushing at least, so it wasn't a complete waste of time.
| 6th-5th grind due to transmission or noob shifting technique? | tracerit | Engine, Exhaust, Transmission | 17 | 03-15-2025 07:44 PM |
| 6th Gear Grind & Replaced Transmission | Bonburner | Issues | Warranty | Recalls / TSB | 45 | 07-30-2016 11:08 PM |
| Transmission - (4th) gear grind | JJJMan75 | Issues | Warranty | Recalls / TSB | 3 | 03-21-2015 02:36 PM |
| transmission grind in 5th gear | Rocket.BRZ | Issues | Warranty | Recalls / TSB | 7 | 06-30-2014 10:38 PM |
| transmission grind | jbailey8748 | Engine, Exhaust, Transmission | 26 | 05-18-2014 09:32 PM |
