Old 04-16-2015, 08:37 AM   #1
reigle jake
Drives: drift cars
which is better frs brz suspension
delete if posted before but i heard the frs suspension is stiffer then the brz
reigle jake is offline   Reply With Quote
Old 04-16-2015, 08:41 AM   #2
Zhangy
Drives: 2015 FRS
for 2013,2014 models brz is stiffer than frs. 2015 probably frs
Zhangy is offline   Reply With Quote
Old 04-16-2015, 08:55 AM   #3
DarkSunrise
DarkSunrise's Avatar
For pre-2015 cars, the FR-S has a softer front spring rate, and stiffer rear.
FR-S: 2.3k front, 3.8k rear
BRZ: 2.7k front, 3.5k rear
Whether that's better or worse will depend on how loose you like your car setup.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
DAEMANO (04-16-2015), strat61caster (04-16-2015)
Old 04-16-2015, 09:42 AM   #4
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
2013 FR-S suspension is best because I own one. Thread over.
Braces is offline   Reply With Quote
The Following 2 Users Say Thank You to Braces For This Useful Post:
Jond63 (04-16-2015), Tcoat (04-16-2015)
Old 04-16-2015, 10:05 AM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
If you like more over steer, 2013-2014 FRS. More balanced...BRZ or 2015 FRS
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Tcoat (04-16-2015)
Old 04-16-2015, 11:30 AM   #6
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
GT86.
Jyn is offline   Reply With Quote
Old 04-16-2015, 11:35 AM   #7
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
The balance is perfect in the 2015 FRS IMO. Flat cornering and grip most of the time. Cure any (almost nonexistent) understeer with a touch of throttle on exit.
V_86 is offline   Reply With Quote
Old 04-16-2015, 11:50 AM   #8
Cole
Not a troll
Cole's Avatar
The best set up is:
For FRS
Front FRS struts with BRZ springs, rear BRZ struts with FRS springs
Rear sway bar removed
For BRZ
Front BRZ struts with FRS springs, rear FRS struts with BRZ springs
Both sway bars removed.
The Following User Says Thank You to Cole For This Useful Post:
murdoc (04-16-2015)
Old 04-16-2015, 11:56 AM   #9
Originally Posted by Cole View Post
The best set up is:
For FRS
For BRZ
I don't think I would enjoy that set up at all!
86geek (04-16-2015), continuecrushing (04-16-2015), Muaddib (04-16-2015)
Old 04-16-2015, 12:25 PM   #10
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
That is one fucked up suggestion.
Muaddib is offline   Reply With Quote
The Following User Says Thank You to Muaddib For This Useful Post:
brianhj (04-17-2015)
Old 04-16-2015, 01:45 PM   #11
Cole
Not a troll
Cole's Avatar
Play on everything @KoolBRZ has done in regards to his suspension.
Tcoat (04-16-2015)
Old 04-16-2015, 01:51 PM   #12
Cole
Not a troll
Cole's Avatar
Want to hear about the custom header I made myself with Harley parts?
The Following 2 Users Say Thank You to Cole For This Useful Post:
Tcoat (04-16-2015), tyrantcf (04-16-2015)
Old 04-16-2015, 01:56 PM   #13
OH dude you had me worried! Your dig was way to subtle.
A "I understand from some that the BEST set up is..." would have gone a long way on that one.
That way it is not a direct slam but gets the veiled sarcasm across to the guys that know what you are referencing.
Cole (04-16-2015)
Old 04-16-2015, 02:27 PM   #14
tyrantcf
Drives: '16 WRX, CBR1000RR
FRS comes with special super drift style suspension. Perfect for someone who drives "drift cars."
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
FS: BRZ OEM Suspension Bizborky Brakes, Suspension, Chassis 8 04-23-2015 07:32 AM
Hello from ISC Suspension-NA ISC Suspension Announcements, Contests, Giveaways 1 03-11-2014 11:08 AM
Suspension Help psyclone07 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-26-2013 03:05 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
