Old 04-15-2015, 03:53 AM   #1
ort895
ort895's Avatar
Added Weight?
So i've been searching for a little while now and i can't seem to find the answer so maybe somebody can help me.
How much weight would i be gaining/ losing going with a Revworks uel header and a perrin 2.5" resonated exhaust?
ort895 is offline   Reply With Quote
Old 04-15-2015, 03:57 AM   #2
wootwoot
Drives: FRS
Not enough to matter.
wootwoot is offline   Reply With Quote
The Following 2 Users Say Thank You to wootwoot For This Useful Post:
Freeman (04-15-2015), Thunderleg (04-16-2015)
Old 04-15-2015, 03:58 AM   #3
ort895
ort895's Avatar
True, just curious as i want to try and shed as much as possible.
Old 04-15-2015, 04:05 AM   #4
Freedom
Freedom's Avatar
Drives: PEARL WHITE GT86 TRD
Lots of goodies here.
http://www.ft86club.com/forums/showt...ht=weight+loss
Maybe you can find the weight specs for your products and compare to above.
Freedom is offline   Reply With Quote
Old 04-15-2015, 04:05 AM   #5
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
You lose 13.8lbs:
http://www.ft86club.com/forums/showthread.php?t=42555
NLSP is offline   Reply With Quote
The Following User Says Thank You to NLSP For This Useful Post:
G-Man (04-15-2015)
Old 04-15-2015, 11:33 AM   #6
ort895
ort895's Avatar
Thank you guys
Old 04-15-2015, 11:52 AM   #7
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
You're better off losing weight higher up in the car than at the lowest point.
JDKane527 is offline   Reply With Quote
Old 04-15-2015, 12:38 PM   #8
Imrac
Drives: 13 SWP BRZ Prem
Are you calling me fat?
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
The Following User Says Thank You to Imrac For This Useful Post:
Koa (04-15-2015)
Old 04-15-2015, 12:40 PM   #9
JDKane527
JDKane527's Avatar
Are you implying you're fat?
The Following 2 Users Say Thank You to JDKane527 For This Useful Post:
BlueDubbinTDI (04-15-2015), weederr33 (04-15-2015)
Old 04-15-2015, 01:25 PM   #10
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Just throwing it out there but... if the operator weighs less, it would be beneficial to both them and the car.
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
AustinG (04-15-2015), Thunderleg (04-16-2015)
Old 04-17-2015, 03:21 AM   #11
ort895
ort895's Avatar
i only weigh 120....i think im good in that area.
Old 04-17-2015, 03:28 AM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Lot of weight can be lightened going w/o codriver .. but there is a catch - you can go faster, if codriver is competent track instructor
fat
Anyone that added aftermarket sub/amp using LOC kberkel Electronics | Audio | NAV | Infotainment 2 09-14-2014 09:53 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 12:38 PM
Crutchfield added FRS/BRZ Roundabout Electronics | Audio | NAV | Infotainment 1 03-01-2013 10:01 PM
Added sub... raphymartinez Electronics | Audio | NAV | Infotainment 4 06-25-2012 09:59 PM
anyone added nav to an fr-s? ssmtsx Electronics | Audio | NAV | Infotainment 10 06-12-2012 11:11 PM
