Old 04-14-2015, 06:00 PM   #1
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
Determining spacers needed with springs?
Hey I was looking for a way to determine the size of spacers I would need to run with the wheels I have and springs I want to get but have been unsuccessful on finding a way to easily determine what I will need before I buy the springs.
Most things I have seen tell you to measure with the springs already on and such but I want to buy the springs and spacers and get them all put on in one go.
I was originally going to go coilovers but after some great info from people on this form it seems like with only hitting the track 3 or 4 days a year springs will be a fine and cheaper solution.
I recently put on my Enkei Kojin 17x9 +45 wheels with 225 +45 wheels (will be going to 245 next set) and I have slight rubbing up at full lock in the front. I plan to drop an 20mm front and back with springs and know without coils I will need more clearance.
Is there a way to figure out the size of spacers I will need to run to not have any rubbing before buying the springs so I can get everyone installed in one go? Dont care about flushed look or anything, just want no rubbing on the perch so I can still track or autoX my car.
Thanks!
Autocon is offline   Reply With Quote
Old 04-14-2015, 06:36 PM   #2
swarb
17x9 +35 seems like a popular choice.
I am going to say 10mm.
For the amount you spend on spacers and springs (~300 a set), I would just use that money towards coils like st's or new tein z's or basis. You could also sell the stock suspension.
Old 04-14-2015, 06:52 PM   #3
8R6
8R6's Avatar
Drives: FRS
8mm to clear, but i dont think ive ever seen an 8mm spacer. so get a 10mm spacer and everything will fit fine. get camber bolts for the front though otherwise the wheel/tire will poke out past the fender with stock camber settings. camber bolts are only like $45 or something new and if you're installing springs, theres no extra step necessary during install. $20-30 used.
8R6 is offline   Reply With Quote
Old 04-15-2015, 05:56 PM   #4
Autocon
Autocon's Avatar
Cool, good to know 10mm will work and about the camber bolts. Thanks
Curious how did you find out that 8 was needed to clear? Just personal experince or is there a way to actually calculate it?
Also love your build!
Old 04-15-2015, 06:05 PM   #5
8R6
8R6's Avatar
Drives: FRS
oops. i miscalculated. i meant 5mm to clear, not 8. and i just based it on my wheels that are 17x9 +38. when i was on springs with oem struts, i had like 3mm of clearance from the spring perch. so with +45, with a 5mm spacer, you'd be a hair away from touching the oem spring perch.
and thanks
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 08:52 AM
spacers needed after installing air ride? BRZ_Kamil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2015 02:21 PM
5mm Spacers Longer Studs Needed? F1fletch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 05-13-2014 11:30 AM
Spacers? Springs? Help. happytimetom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-24-2014 07:38 AM
What extra work is needed after installing springs? g0ast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-04-2013 08:15 PM
