Old 05-12-2014, 02:37 PM   #1
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
5mm Spacers Longer Studs Needed?
I see a couple vendors sell these and most if not all seem to come with new longer studs. Are they really needed for only 5mm?
F1fletch is offline   Reply With Quote
Old 05-12-2014, 02:54 PM   #2
wparsons
wparsons's Avatar
The stock studs are barely long enough without spacers, I think most people find 3mm safe but anything more you should get longer studs.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Kido1986 (05-13-2014)
Old 05-12-2014, 03:03 PM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I'll sell you my extended studs
Old 05-12-2014, 04:10 PM   #4
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
I take it you didn't use them. Why not?
Old 05-12-2014, 08:35 PM   #5
diss7
Drives: AE86, 2x GT86, TE27
I tried 5mm spacers on and it was dodgy. Rules over here state you need 6 rotations of the nut on the stud. I barely got three. Not good.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
F1fletch (05-12-2014)
Old 05-13-2014, 05:58 AM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes you will need extended studs for 5mm spacer. I've got the 50mm Nismo studs and they're just the right length....long enough to have full lug nut engagement, but not too long to stick out like a sore thumb.
Fizz is offline   Reply With Quote
Old 05-13-2014, 08:11 AM   #7
BlueDubbinTDI
Eh we torqued them down to 71ft lbs and theyve been fine
Old 05-13-2014, 10:25 AM   #8
jflogerzi
jflogerzi's Avatar
Why not get the bolt on ones?
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 05-13-2014, 11:30 AM   #9
BlueDubbinTDI
I'll say it again, mine are H&R brand and you can have them for $20 shipped.
3mm spacer...need longer studs? Fizz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-16-2014 02:50 AM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 08:55 AM
spacers and stock studs abutterman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-17-2013 10:55 PM
Spacers / Studs VOID Warranty? N_I_N Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-30-2013 03:32 PM
Longer wheel studs for those with spacers 000 Racing AUSTRALIA 0 03-20-2013 06:41 AM
