Old 04-09-2015, 07:19 PM   #1
86Tony
Drives: 2015 AOZORA EDITION
Pentosin or Motul gear 300
So I have pentosin in my car right now it feels good but I feel that it's to thin for me to be tracking. I want to try motul but i have read mix reviews about them. What is your opinion on both these oils and should I just stick with oem oil instead??
86Tony is offline   Reply With Quote
Old 04-09-2015, 07:21 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
motul 300 hands down. I and MANY others have switched to it, and I will continue to use this in the future.
Old 04-09-2015, 07:59 PM   #3
Ferrari
Ferrari's Avatar
Drives: Taking the bus
You could also try Redline MTL. It's the same viscosity as OEM. Motul was horrible in my transmission, and Pentosin is much better. I don't track my car.
Ferrari is offline   Reply With Quote
Old 04-09-2015, 08:12 PM   #4
swarb
motul gear 300 here. I changed at 5600miles and it feel less notchy going into second as more time passes. at 7k now. It could also be the warmer weather.
Old 04-09-2015, 08:19 PM   #5
SR5
SR5's Avatar
Drives: Raven
Thumbs up Motul 300
I have Motul 300 and I feel it's not worse than oem in the cold and feels smooth since I do a lot of heel-toe, blipping, matching the speed before engaging the gear. Also read good things on Pentosin for cold shifts, and Motocraft XT-M5-QS for track and daily driving.
Ever since I got the car, main problem for me is 3rd gear and not 2nd gear like most. Do you guys think I should go with Motul 300 for the diff also?
SR5 is offline   Reply With Quote
Old 04-09-2015, 09:44 PM   #6
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by swarb View Post
motul 300v here. I changed at 5600miles and it feel less notchy going into second as more time passes. at 7k now. It could also be the warmer weather.
300V is actually motor oil...
-mike
AZP Installs is offline   Reply With Quote
The Following 2 Users Say Thank You to AZP Installs For This Useful Post:
Laika (04-19-2015), swarb (04-09-2015)
Old 04-09-2015, 09:46 PM   #7
AZP Installs
We use the Motul Gear 300 75w90 in both our street cars as well as our track cars right up to our Spec86 Cup Wheel to Wheel Race Car.
It is also the fluid we use in all our customer cars for their gear oil and rear diffy fluid changes. Probably have 50-100 FRS/BRZs running around with this fluid in them that we installed over the past 2 years.
We also offer a 4 Liter package shipped for $85 so let us know and we can get you setup with it.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
The Following User Says Thank You to AZP Installs For This Useful Post:
SR5 (05-11-2015)
Old 04-09-2015, 09:54 PM   #8
continuecrushing
motul 300 in the diff is a great idea!
The Following User Says Thank You to continuecrushing For This Useful Post:
SR5 (04-10-2015)
Old 04-09-2015, 10:02 PM   #9
86Tony
Thanks for your guys input, I will try out motul this weekend to find out for myself. I let you guys know how it feels compared to pentosin. Since I drive hard this oil should be a no brainer I guess
Old 04-09-2015, 10:22 PM   #10
toby714
Drives: whiteout
i had the opportunity to try both. i prefer the motul fluid
toby714 is offline   Reply With Quote
Old 04-10-2015, 01:02 AM   #11
RJasonKlein
RJasonKlein's Avatar
I highly recommend Millers Oils CRX 75W90 NT. At the risk of sounding like I'm evangelizing, it's remarkable and totally unique in the marketplace and worth researching. It's expensive, but it works very well in our Aisin transmission.
RJasonKlein is offline   Reply With Quote
Old 04-11-2015, 05:10 PM   #12
86Tony
Switch to motul and loving it much more then the pentosin. Everything is butter now
Old 04-11-2015, 07:33 PM   #13
protpibe
protpibe's Avatar
I've used Motul 300 and Amsoil severe gear, and Motul 300 is better by a large margin. it's so good that I actually have no complaints about it, and have no desire to try anything else. Shifts are slick and smooth at any temperature, on the street or at the track.
Old 05-11-2015, 01:40 AM   #14
SR5
SR5's Avatar
Drives: Raven
Smile Motul Gear 300 75w90
..should go with Motul 300 for the diff also?
Just revisiting my post.. Today (13.3k miles) just switched the dirty OEM Differential fluid with the same Motul Gear 300 75w90 that I put in the tranny.
(Magnetic Plug before and after pics below).
It feels way better! To describe it, everything spins freely now.
Now it really feels like a RWD car. Launches are better, rises quicker even under normal driving launches. ..I found myself giving it more clutch between shifts sometimes it spins too freely.
The Following User Says Thank You to SR5 For This Useful Post:
Bonburner (05-11-2015)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Where to buy Motul 300 gear oil in GTA? nocwage CANADA 6 08-25-2014 08:39 AM
Where to get Motul Gear 300 in the GTA? automatic CANADA 5 04-09-2014 05:48 PM
No Motul Gear 300?? markmatley Hawaii 14 04-17-2013 09:59 PM
