Old 04-09-2015, 08:19 AM   #1
shortcut
Drives: Frs 2013
Question Maf sensor max out
Hey,
I am running kraftwerk c30 kit and I am maxing out the maf at 6500rpm.
Is there a maf more powerful and direct fit out there?
Thanks
shortcut is offline   Reply With Quote
Old 04-09-2015, 08:33 AM   #2
Shady195
Drives: '13 10 Series FRS #1203
Originally Posted by shortcut View Post
Hey,
Thanks
http://www.rallysportdirect.com/Omni...Bar-MAP-Sensor
Shady195 is offline   Reply With Quote
Old 04-09-2015, 08:38 AM   #3
shortcut
Drives: Frs 2013
Originally Posted by Shady195 View Post
I have a 4 bar MAP installed right now. The one that is maxing out is the MAF. It is reading 4.9 volt and don't want to go higher.
Old 04-09-2015, 08:45 AM   #4
Shady195
I apologize, just read quickly.
I have not looked THAT much but I don't recall seeing a note of anyone replacing their MAF sensors even with higher HP builds than that Kraftwerks kit would put out..
Old 04-09-2015, 09:11 AM   #5
vgi
Drives: frs
maf sensor should not max out on c30 on standard pulleys and pump gas, check if it's sitting correctly (maybe twisted a bit) and that o-ring is not ripped. otherwise you'd need to do an SD or hybrid tune.
vgi is offline   Reply With Quote
Old 04-09-2015, 09:25 AM   #6
mrk1
Drives: Sterling BRZ Ltd
Hybrid tune would be the solution but as already said I'm surprised to see it max out. Also have you checked at all if your tune does not already have some sort of hybrid setup to it for the higher rpms. With a SC being so linear and consistent I would think your tuner would already have seen this.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-09-2015, 09:48 AM   #7
shortcut
Drives: Frs 2013
More info : We were tuning in 0 degre celsius. That might help understand why it is maxing out for me and not for other people with the same setup.
My tuner is using BRZedit so I don't think it support Speed density.
Sorry I am a newbie for tuning terms, what does Hybrid tune means?
Old 04-09-2015, 09:54 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Your options are switch to EcuTek and run a full or partial speed density tune or modify the pipe that houses the MAF sensor so that you don't exceed the max voltage. Bigger pipe, less air flow, lower voltage.
The Following User Says Thank You to King Tut For This Useful Post:
Sportsguy83 (04-10-2015)
Old 04-10-2015, 11:16 AM   #9
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
Mine was maxed out. So bought a 700whp one.
471whp/368TQ@16lbs. BW EFR 7064 recently sold
Fabron757 is offline   Reply With Quote
Old 04-10-2015, 11:46 AM   #10
shortcut
Drives: Frs 2013
Could you tell me the model number of the MAF?
Old 04-10-2015, 12:08 PM   #11
mrk1
Hybrid means it switchs between MAF readings and speed density. This allows the best of both worlds. Simply enlarging the pipe would work but would have side effects at lower rpms. I believe the KW is already a 3" tube anyway.
The Build Thread
Old 04-10-2015, 01:29 PM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Hey,
Thanks
Speed Density via Ecutek or any standalone would be your top choices.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
cdrazic93 (04-10-2015)
Old 04-10-2015, 02:34 PM   #13
Fabron757
I'll let you know the model number when i get back in town tomorrow.
Old 04-10-2015, 07:45 PM   #14
shortcut
Drives: Frs 2013
Yes, Kraftwerk use a 3" tube and my tuner use BRZedit so no speed density for me.
My tuner use BRZedit and it doesn't support speed density.
Thanks
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
02 Sensor mjsivee Engine, Exhaust, Transmission 4 06-13-2013 01:58 PM
