Mishimoto thermostatic sandwhich - NPT clearance
Anyone out there with the mishimoto thermostatic sandwich plate able to confirm if the NPT ports actually have clearance to use a sender, say oil temp?
By photos looks like the left side is very close to accessory belt and right is very close to oil fill cover. @Mishimoto thanks!
#2 | |
Drives: 2013 Subaru BRZ
![]() Do keep in mind, this sandwich plate can be clocked in either direction to provide fitment with large aftermarket airbox setups or to fit a sensor. It will depend upon the sensor in question, regarding if the size and shape will be applicable. During testing we actually use in-line pressure and temperature sensors so the NPT ports are not actually used for R&D purposes. If they were this would be a bit easier to answer. Any idea what particular sending unit you were going with? Thanks -John |
@Mishimoto thanks for the response John - will be looking to install a ~1 inch oil temp sender, any thoughts? Photo seems quite tight!
Also, I noticed that the ports already seem to be plugged with Teflon, is that right or are my eyes deceiving me? Just want to check if I need to replug the side I don't intend on using.
Drives: Sterling BRZ Ltd
I was able to turn my sandwich plate to towards the driver side and squeak in a temp sensor on the AC compressor side port. Its definitely a little disappointing I cant use both side ports.
#5 | |
so you installing a second oil temp sender ? any reason ? |
@steve99 pre cooler and post cooler readings. A bit overkill but I have the gauge already and pod has the extra space Haha.
| The Following User Says Thank You to 1Cor10:23 For This Useful Post: | steve99 (04-19-2015) |
#7 | |
Our sandwich plates come with these plugs pre-installed with teflon tape. When you install the sending unit for your gauge, we do recommend using teflon tape or a liquid sealant. Let us know how it goes! -John Thanks for chiming in! |
| Mishimoto Thermostatic Oil Cooler and Rad Combo Pacakge! // DSG Performance | Jason@DSG | Engine, Exhaust, Bolt-Ons | 8 | 08-27-2014 04:07 PM |
| Mishimoto Radiator & Blue Mishimoto Hose Kit | tlinspired830 | Engine, Exhaust, Bolt-Ons | 6 | 03-24-2014 10:34 PM |
| TRD clearance? | BadRix | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-10-2014 11:23 AM |
| 17s & BBK clearance | ultra | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 02-04-2014 04:53 AM |
| Mishimoto Radiator & Mishimoto Radiator Hose Kit | tlinspired830 | Engine, Exhaust, Bolt-Ons | 5 | 01-08-2014 08:44 AM |
