| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Is this a bad crank bearing?
Girlfriends sons Explorer us making this noise. It happens under power with a load but doesn't stop immediately when you let off. Does it sound like a crank bearing? Power seems fine, just the noise.
will it make the sound while standing still in neutral?
Will the sound continue if you put it in neutral while moving? will the frequency change with rpm or speed? hard to tell but bearing in alternator or idler would be a place to look. |
not playing cards
That's not anything internal. My guess is belt tensioner.
#4 | |
- It doesn't happen in neutral without any load - Frequency doesn't change with engine or car speed I'll pull the stethoscope out and check all the pulleys whenever he finally comes out. I'm not sweating it too much. Thanks for the input!
| Second time crank seal leak possible crank walk | kiichiro | Engine, Exhaust, Transmission | 13 | 09-19-2018 05:57 AM |
| Throw-out bearing | mhigham | Issues | Warranty | Recalls / TSB | 71 | 08-18-2016 10:21 AM |
| Release Bearing or Pilot Bearing | Cal3000 | Engine, Exhaust, Transmission | 11 | 01-27-2015 10:39 PM |
| Lightweight Flywheel + Crank Pulley: Bearing Failures? | Anthony | Engine, Exhaust, Transmission | 23 | 01-24-2015 12:10 PM |
| bearing identification | paraguin | Other Vehicles & General Automotive Discussions | 7 | 04-16-2013 10:18 AM |
