Old 04-02-2015, 11:53 AM   #1
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Wheel lock install question
I'm a novice on anything wheel related. I bought wheel locks (always had them on other cars). To install, can I just take out the one lug nut and install the lock? Or do I need to completely do up all of them in a star pattern?
If I can do just the one, does it need to be jacked up off the ground
V_86 is offline   Reply With Quote
Old 04-02-2015, 02:47 PM   #2
8R6
8R6's Avatar
Drives: FRS
loosen one lug
raise the car
remove loose lug
hand-tighten wheel lock
lower car
torque wheel lock to spec (i think it was 89 lb.-ft.)
8R6 is offline   Reply With Quote
Old 04-02-2015, 03:12 PM   #3
V_86
V_86's Avatar
I'll get a torque wrench then. Any suggestions on a good brand that's fairly inexpensive?
Old 04-02-2015, 03:25 PM   #4
samfrs
Custom User Title
Drives: FRS
http://m.harborfreight.com/hand-tool...rench-239.html
samfrs is offline   Reply With Quote
Old 04-02-2015, 04:20 PM   #5
CoupedUpSubie
Drives: 2013 BRZ Limited
You don't even need to jack the car up. The lug nuts used on these cars are tapered, they won't let the wheel move at all. I've swapped one lug nut at a time so many times it's not funny. Just make sure you torque it and check the others.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 04-02-2015, 04:34 PM   #6
qoncept
qoncept's Avatar
I wouldn't bother with a Harbor Freight torque wrench. I honestly think you'd be no worse off with any old pry bar. If you want to make sure your lugs are torque to spec, get a better torque wrench, otherwise just do it by hand.
qoncept is offline   Reply With Quote
Old 04-09-2015, 09:30 PM   #7
V_86
V_86's Avatar
Got a torque wrench, did what BRG said, minus jacking up car.
Lost wheel lock nut - what to do next? Trikle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-17-2015 12:55 PM
Window and door lock switch Illumination question. HapaHaole BRZ First-Gen (2012+) — General Topics 0 03-05-2014 09:14 PM
where is the wheel lock key? fatoni Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-21-2013 11:32 AM
Wheel lock on only one per wheel: unbalanced? stocktc1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 03-24-2013 11:37 AM
