Old 04-01-2015, 12:54 PM   #1
nbar1
Drives: 2015 WRB BRZ
Dual Climate Control LED Issue
So, this is kind of a weird issue but I hope someone has encountered and fixed it before I call the dealer. I don't know when this started happening, but recently when the "Dual" LED is lit up, the temp controls are independent, and when I hit the switch and the LED is off, the temp controls are combined. It seems that this is now backwards. Anybody ran into this?
nbar1 is offline   Reply With Quote
Old 04-01-2015, 01:27 PM   #2
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Wut? When Dual LED is lit, its supposed to allow each side a unique temperature. When its not lit, each side will be forced to be identical.
If its doing the opposite, I dunno - try disconnecting the negative battery terminal for a bit to reset virtually everything. If its not back to normal call the dealer?
SpectreRT is offline   Reply With Quote
Old 04-01-2015, 01:57 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
What you described above in red, is the correct way of operation. If it's behaving like that, there is nothing wrong with it.
Old 04-01-2015, 02:24 PM   #4
PhantomX
INTJ
PhantomX's Avatar
Drives: 2017 86 860
Dunno if serious or April Fools...
PhantomX is offline   Reply With Quote
Old 04-01-2015, 10:22 PM   #5
BRZnut
Drives: BRZ DGM Limited
mine works that way too.
I also noticed that when I push the gas pedal my car goes faster.
Automatic dual climate control harness Sangthing Electronics | Audio | NAV | Infotainment 209 05-19-2023 12:16 AM
Climate Control Issue amishdude01 BRZ First-Gen (2012+) — General Topics 32 12-17-2014 04:15 PM
BRZ limited dual climate control Sangthing Interior Parts (Incl. Lighting) 6 09-12-2014 06:01 AM
Ac knobs for BRZ limited / FRS with dual climate dnizzle Cosmetic Modification (Interior/Exterior/Lighting) 3 08-15-2014 10:43 PM
FS - BRZ Dual Climate Control Unit dvsidboy Audio/Visual, Electronics, Infotainment, NAV 4 01-12-2014 08:52 PM
