Old 03-30-2015, 08:37 AM   #1
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Longer Exhaust Hangers for Injen SES
Okay I made a post about this in one of the threads for the Injen SES exhaust but I guess not many people look at that thread anymore.
So my issue is that the tips touch the bumper and the shop that installed it for me couldnt find a way to adjust them to sit properly. Maybe something is different with 2015 compared to the older MYs? I dont know.
Now I need some longer exhaust hangers.
Are these the right ones? http://www.rallysportdirect.com/Kart...st-Hanger-Long
And I only need two for the rear right, I dont need to replace the hangers throughout the exhaust?
EDIT: Maybe @RallySport Direct can help me out here?
PandaSPUR is offline   Reply With Quote
Old 04-05-2015, 08:07 PM   #2
AleConquistador
Drives: Scion FRS 2013 AT
Longer exhaust hangers are definitely needed!
I took my car to a track day and my exhaust got so hot it melted the plastic in my rear bumper. Now I have a hole about the size of my wrist; and my exhaust is about 1'' away from the bumper. I'll consider Cusco exhaust hangers that are a bit longer.
AleConquistador is offline   Reply With Quote
Old 04-05-2015, 08:47 PM   #3
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
you need to replace all 5 exhaust hangers
andrew5826 is offline   Reply With Quote
Old 04-05-2015, 08:58 PM   #4
PandaSPUR
PandaSPUR's Avatar
Speaking from experience? I only bought four, waiting for them to get in so I can swap em out.
Old 04-05-2015, 11:02 PM   #5
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
i wouldnt say so if i wasnt. you might be able to get away with just the rear 2 but definitely not 4. get under your car and you'll quickly realize why..
Old 04-06-2015, 08:37 AM   #6
PandaSPUR
PandaSPUR's Avatar
Hm now I'm confused, why would 2 work but not 4?
Does putting all 4 pull the rear too far down for the midpipe hanger to handle?
I want to avoid changing the midpipe one since I have no driveway or garage. So changing that one would mean I actually need to go bother someone who can lift my car.
Old 04-06-2015, 08:08 PM   #7
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
If you get polyurethane bushings (the Kartboy XLs are what I'll be using tomorrow) you can replace 4 of the 5 hangers. Specifically, if you remove the hanger supporting the mid-pipe and replace the 4 on the muffler you should be fine.
Or, try replacing the 2 on the rear of the muffler. In theory, it should drop the muffler a little bit. I'll let you know how it works out for me tomorrow.
SpectreRT is offline   Reply With Quote
Old 04-06-2015, 10:33 PM   #8
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
yes the stock hangers cant stretch that much. you can get away with removing the midpipe one and just running 4 on the muffler part but it isnt ideal
Old 04-06-2015, 11:30 PM   #9
PandaSPUR
PandaSPUR's Avatar
Hmm.. so to be clear, my choices are:
1. Replace all 5
2. Replace the rear 4 and remove the midpipe hanger
3. Replace only the 2 by the mufflers
Is that correct?
Rubber exhaust hangers JimmyMac Engine, Exhaust, Transmission 20 06-19-2014 12:56 PM
Exhaust Hangers FrSnake Engine, Exhaust, Transmission 11 01-20-2014 01:45 PM
exhaust hangers jazztennor Engine, Exhaust, Transmission 7 02-19-2013 09:57 AM
Exhaust hangers yomchi1989 AUSTRALIA 4 12-01-2012 01:15 AM
Rusty exhaust hangers? finch1750 Issues | Warranty | Recalls / TSB 5 11-12-2012 12:29 AM
