Old 03-28-2015, 04:36 PM   #1
nickw14
Drives: Built FA20
AFR table
Here is a log that I took about a week ago: http://datazap.me/u/nwilging/gfy?log=0&data=1-9
I noticed that at 0% throttle, and at idle, my AFR goes up to 20. This seemed strange, so I started looking around the tables to see where it is getting this value from. Well, I can't find it anywhere....
The closest thing I can find is Fueling Primary Open Loop\Primary Open Loop Fueling table. However, idle values in this table are the normal 14.7. Where does the AFR for closed loop come from? Or is there just a corrections table that uses the values from the open loop afr table?
Thanks for the help.
nickw14 is offline   Reply With Quote
Old 03-28-2015, 05:37 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
It should only show 20 when there is no fuel being injected, like on the overrun. Idle should still be around 14.7.
Open loop fueling is just the open loop commanded AFR, there are 2 closed loop compensation tables.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
nickw14 (03-29-2015)
Old 03-30-2015, 02:57 PM   #3
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I don't think the table to adjust overrun fuel cut has been defined yet.
Toyota John is offline   Reply With Quote
Old 03-31-2015, 03:00 PM   #4
nickw14
Drives: Built FA20
I haven't seen a table that looks like overrun fuel cut. Although I haven't really been looking either.
Right now I am trying to decipher these "conversion factors" between the OL afr table and the CL compensation tables... They're all negative numbers...
Old 03-31-2015, 07:34 PM   #5
PantsDants
Drives: Scion FR-S A/T, Whiteout
In RomRaider, for a given load/rpm cell, you add the value to stoichiometric (14.7) to get your targeted AFR. For example, say a cell is at -1.0, then you'd have:
14.7 stoichiometric + (-1.0 compensation) = 13.7 target AFR
There are other, undefined compensations in the ROM as well, but this is roughly how the ECU gets what AFR to target in closed loop. Also note that lean adjustment (that is, positive numbers in your table) won't do anything; you can't target anything leaner than 14.7 using the load compensation tables.
PantsDants is offline   Reply With Quote
The Following User Says Thank You to PantsDants For This Useful Post:
86TOYO2k17 (04-04-2019)
Old 04-01-2015, 09:15 AM   #6
nickw14
Drives: Built FA20
Well that's what I thought at first, but then I compared those values to the actual AFR. Which brings me back to the original post: under certain driving conditions AFR leans out to 20.
What you're saying makes way more sense though. I suppose it could be yet another table that holds the values or compensation values to lean the afr out that much...
Old 04-01-2015, 12:23 PM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
Can you post a log or explain exactly when you're going to an AFR when there is no fuel being injected? It should only show 20:1 when you come off the throttle. If it's when you step on the throttle something is very wrong and you'd feel it as it would hesitate. There would be absolutely no power being made. There are no tables that would allow it to go that lean.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-01-2015, 02:39 PM   #8
nickw14
Drives: Built FA20
I only noticed it when I looked at the logs in the first place, so I haven't went back out to test when it is 20:1. You are correct, when I am off the throttle the AFR does jump up, but it also does this at idle. Any time I am on the throttle it does not appear to be abnormal.
I guess I am confused as to where it's finding these values.
Is no fuel being injected even on deceleration?
Old 04-01-2015, 03:56 PM   #9
Koa
not sure if it's a hard fuel cut or significantly pulled back (I'm leaning towards the latter). Kode or someone else will chime in with a definite answer. Here's a few threads to help glean an understanding of what goes on during deceleration in gear
http://www.bobistheoilguy.com/forums...Number=2876999
http://ecomodder.com/forum/showthrea...off-22374.html
http://www.city-data.com/forum/autom...-coasting.html
Old 04-01-2015, 05:14 PM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
It shouldn't do it at idle, but yes the fuel injectors shut off on overrun/deceleration.
.: Stealth 86 :.
Kodename 47 DJ:
f.s. Open flash table slofrs Engine, Exhaust, Bolt-Ons 3 12-31-2014 10:07 AM
2014 PAX table Scooby South Tracking / Autocross / HPDE / Drifting 11 11-26-2013 10:35 AM
ECU table functions and definition of tables brn12345 Software Tuning 7 11-14-2013 08:45 AM
Help posting a Table / Spread sheet Esoteric Site Announcements / Questions / Issues 1 07-27-2013 11:48 PM
Coffee table I made from my FRS OEM springs FR-Shadow Scion FR-S / Toyota 86 GT86 General Forum 25 12-16-2012 06:05 PM
