Old 03-24-2015, 11:52 PM   #1
Drakelee117
Drives: Subaru BRZ 2015
Possibly stupid question, what's the point of BHP per liter?
BHP per liter is sometimes used as an important standard for an engine. But what's the point for this number since it doesn't take the number of cylinders in account? I mean, how is a 2 liter 4 cylinder engine like the one the twins have comparable to those 5 liter V8s just because they produce similar BHP per liter number? And this next question might sound stupid, but if cylinder number does not matter, why don't car makers make 8 liter 4 cylinders that kind of crazy stuff?
Drakelee117 is offline   Reply With Quote
Old 03-25-2015, 12:02 AM   #2
tyrantcf
Drives: '16 WRX, CBR1000RR
It is specific output per unit of displacement.
Useful for comparison purposes with other data and against other engines to help determine overall efficiency.
An engine with a higher specific output per unit of displacement is more efficient in terms of making power.
And 8 liter 4 cylinder? Because it would be fuckin huge? one head would displace what the whole fa20 displaces. Would be cool though!
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 03-25-2015, 12:51 AM   #3
Beil
Drives: 2015 WRB Limited
well, with bigger engines, the number of cylinders tend to grow for a variety of reasons.
This is just my opinion as an engineer, but if you had 4 REALLY BIG cylinders instead of 8-10 smaller ones, you'd run into problems with the fuel/air mixture not completely burning up in time. To counteract this, you'd have to slow the RPM's down drastically to allow the fuel/air to burn completely. Or you could always have hotter spark plugs, but that will also lead to higher overall heat in the engine(which opens another different can of worms.)
Also, with the larger and heavier pistons, the stresses on the connecting rods and crankshaft are more concentrated to a specific area, so you'd have to beef those up as well, leading to an unnecessarily heavy setup.
I could be completely wrong on this, but I think there is a way of optimizing the number of cylinders with displacement. Fewer cylinders does make for fewer moving parts and more simple design, but the forces are concentrated on fewer moving parts. More moving parts lowers stress concentrations, but also makes for a much more complicated design.
with that being said, would I love to see an 8 liter 4-cylinder? hmmmm....pistons bigger than my head? sounds like fun!!!
Beil is offline   Reply With Quote
Old 03-25-2015, 01:02 AM   #4
extrashaky
Drives: 2014 BRZ Limited
How 'bout a 28 liter 4 cylinder?
[ame="https://www.youtube.com/watch?v=PlPbhGeMu4U"]Fiat S76. 1911. 28.4 litres. 4 cylinders. Start-up 28th Nov 2014. - YouTube[/ame]
The Following User Says Thank You to extrashaky For This Useful Post:
Ultramaroon (03-25-2015)
Old 03-25-2015, 01:18 AM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
do NOT throw those rods....lol
Old 03-25-2015, 01:35 AM   #6
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Holy moly. Is that an engine or an out of tune missile!
Got a link to it being driven?
nzer is offline   Reply With Quote
Old 03-25-2015, 01:53 AM   #7
retoocs
It's about efficiency. American engine builders try to shoot for 1 hp per cubic inch. The rest of the world tries to get 100 hp / liter. Do the math, which is a more efficient engine?
retoocs is offline   Reply With Quote
Old 03-25-2015, 03:25 AM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Because engineering. Over 100 years of engineering.
+ accounting.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Captain Snooze (03-25-2015)
Old 03-25-2015, 03:41 AM   #9
swarb
Also racing. Rules limit engine sizes so if you make more power, you are potentially faster. And in some countries, there is a tax for bigger engines.
Old 03-25-2015, 06:06 AM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
My impression is that power/capacity is a relic from years gone by. Back when peak power was all that mattered because the spread was so narrow the maximum dictated performance.
This is just conjecture on my part.
Old 03-25-2015, 02:50 PM   #11
Drakelee117
Which has a bigger effect on power output? And how? Number of cylinders or displacement
Old 03-25-2015, 03:29 PM   #12
navanodd
Drives: 2013 BRZ Sport-tech WRB
Displacement.
The amount of power you can produce is primarily determined by how much fuel you can burn.
It takes 15 parts air to burn 1 part fuel (by mass) and the biggest struggle with any engine is getting enough air in so that you can burn the amount of fuel you want to burn.
The bigger the engine displacement, the more air in the engine to burn the fuel, so the more energy you get per each cycle.
The only other fundamental way to get more air into an engine is to compress it, this is where turbo or superchargers come in.
Now, what I've mentioned above is true for one engine cycle, or assuming that each engine type is rotating at the same speed. If you double an engine's speed you (ideally but not quite true in reality) double to rate at which it intakes air and produce more power that way.
There are of course a bunch of different efficiencies that affect the overall power that the engine will produce for a given amount of fuel (# of cylinders would impact these efficiencies), but basically there are 3 ways to make an engine have more power:
1. Make it bigger
2. Turbo/supercharge
3. Make it faster
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
Drakelee117 (03-25-2015)
Old 03-25-2015, 03:49 PM   #13
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
Power/displacement is used to determine how efficient an engine is.
Number of cylinders, bore, stroke, compression, and camshaft profile will be determined by and determine what the engine is used for. Whether it's low revs/high torque or high speed/low torque. There's obviously more to it but in general certain configurations are better for certain applications.
Amaya is offline   Reply With Quote
Old 03-25-2015, 04:17 PM   #14
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
That's not true anymore in the modern American car market....
Sorry, stupid EL vs. UEL question... Tromatic Engine, Exhaust, Transmission 63 06-08-2014 07:03 PM
stupid question about brz andrewmay9 BRZ First-Gen (2012+) — General Topics 55 05-17-2014 03:10 AM
Really stupid question regarding oil hansthegerman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 10-08-2013 07:56 AM
Possibly stooopid bluetooth question Larkin Electronics | Audio | NAV | Infotainment 1 09-16-2013 07:10 PM
Stupid Question Canibuz Engine, Exhaust, Transmission 24 03-05-2012 09:50 AM
