Old 03-12-2015, 02:49 PM   #1
Simok
Drives: 2013 FRS
OEM 4th Brake Light.
I have only seen a few kits out there, and some DIYS. I was just wondering which the best kit on the market is. Also if someone has made one that functions the same as the stock tailights, ie: Lights are on it acts as a tail light, brakes pressed lights up brighter as a brake light, lights off, just a normal brake light. If there is not one of these out there how hard would it be to DIY one?
I don't have much experience with auto electrical. I can read wiring diagrams and schematics. I'm not even sure what the connector for the tail light looks like (Have to check when I get home). My thought was just get another tail light bulb socket and some long wires and connect them together, how ever I feel like if it was that easy someone would have done it already. Any thoughts or input would be nice.
Simok is offline   Reply With Quote
Old 03-12-2015, 06:40 PM   #2
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
http://www.phasteksport.com/2013-Sci...z-rear-fog.htm
This is the kit that I bought when I did mine, it does exactly what you describe you want it to. I've had it installed over a year now and no problems.
The main reason I went with a kit was because I've never really done much with wiring and lighting on a car so I was afraid of screwing something up on my brand new car lol. But the install over all is pretty easy. The hardest part for me was getting the light housing out and drilling the hole for the light socket.
Here's another one as well:
http://store.ijdmtoy.com/Scion-FR-S-...Y-p/75-224.htm
Husker BRZ is offline   Reply With Quote
Old 03-12-2015, 06:45 PM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
i too went with the same kit @Husker BRZ mentioned
very straight forward install, took me about 30 minutes, hardest part IMO was cutting the hole into the rear fog light, i was just worried i would make the hole bigger than the bulb itself
other than that. its straight forward
Old 03-12-2015, 09:07 PM   #4
Simok
Drives: 2013 FRS
Oh cool I was actually just looking at that kit. I might have to go with that. No complaints? Install advice?
Old 03-12-2015, 09:13 PM   #5
Gunman
Drives: 2019 Mazda Miata RF
I went 100% DIY, might have $30 invested, but in retrospect I could have redesigned a bit, and saved a few bucks. Light works as a parking light, and when brakes are applied it changes to a blinking stop lamp.
Gunman is offline   Reply With Quote
Old 03-12-2015, 09:19 PM   #6
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
How'd you get it to blink when pressing the brake I've been wanting to do that to my aftermarket replacement.
Old 03-12-2015, 09:32 PM   #7
Gunman
Turn signal flasher. I also used a relay to cut the parking light off when the brake is applied, so the flasher stands out more.
Old 03-12-2015, 09:43 PM   #8
AzureShadow
Drives: 2015 Subaru BRZ Limited 6MT WRB
I am really looking for something that works with the OEM light as a fog normally, but when the brake is applied it does kind of the F1 triple flash then solid bright.
Haven't quite found anything yet. I may end up just making something.
AzureShadow is offline   Reply With Quote
Old 03-14-2015, 07:27 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm going for a little more complex method...
Old 03-15-2015, 05:32 AM   #10
KayC
Drives: 2013 whiteout FRS 6mt
Got the nsidius industries kit. 100% plug and play for the wiring. No splicing required
KayC is offline   Reply With Quote
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 08:14 PM
Reverse Bar / 4th Brake Light without a Light Bar? (to match OEM tails) cdo221 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-20-2015 01:24 AM
4th Brake Light/Rear Fog Light Kit FRS/BRZ/GT86 - $59.95! Vicious LED Groupbuys 58 01-05-2014 05:13 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
