Old 03-11-2015, 12:07 PM   #1
KingGT86
Drives: Raven FRS 2014
Will these fit?!
My plan is to get my hands on ESM 004 17x9 5x100 et38 cb57.1
Now my question for you expert on wheels and tires is... Will these fit on the stock tires?? And also with the sport line lowering kit??
Thanks in advance for the help!!
KingGT86 is offline   Reply With Quote
Old 03-11-2015, 12:19 PM   #2
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
http://www.ft86club.com/forums/showthread.php?t=15007
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
JohnJuan (03-11-2015)
Old 03-11-2015, 12:22 PM   #3
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Yes stock tires will fit but with a stretch. You can get any lower springs you want and it will fit. If you want adjustability then get coilovers but they cost a bit more. Hope this helps
DavidBob is offline   Reply With Quote
Old 03-11-2015, 12:28 PM   #4
KingGT86
Originally Posted by No5ki View Post
Stock tires will stretch. The wheels wont rub though.
Thank you guys, is it bad for the tires to stretch?? It's only till I can get my hands on some good tires.
Old 03-11-2015, 12:32 PM   #5
WhiteFRS69
WhiteFRS69's Avatar
yea... please dont stretch your tires...
Old 03-11-2015, 12:57 PM   #6
Brndn704
Brndn704's Avatar
LMFAO, to you ppl that think stretching tires is "bad". C'mon now. I was running 205/35's on a 18x9.5 and never had any issues. OP, this is the worst possible place to ask this question, go to the Aggressive wheel thread where people actually know what tf they are talking about.
Brndn704 is offline   Reply With Quote
The Following 2 Users Say Thank You to Brndn704 For This Useful Post:
Loetke (03-11-2015), Tcoat (03-11-2015)
Old 03-11-2015, 01:13 PM   #7
KingGT86
Help!!
Okay guys so I'm gettin my hands on some ESM 004 17x9 et 38 cb 57.1 wheels.. And was wondering if it's okay to put these on the stock tires( yes I know they'll stretch) but this is until I can get some better tires..
Also when I do decide to get some new tires which would fit best for this rim? Also I will have eibach sport line springs installed..
Thank you guys!
Old 03-11-2015, 01:21 PM   #8
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
http://www.ft86club.com/forums/showthread.php?t=7535
Its not really that hard is it? You completely passed up the stickies that are on top of the page.
Also, putting 215's on a 9 inch rim will be VERY stretched. I don't know if it'll work very well.
Bobblehead is offline   Reply With Quote
Old 03-11-2015, 01:26 PM   #9
gramicci101
Off Topic
Why not just leave them stacked in the garage until you get wider tires?
Old 03-11-2015, 01:35 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Okay? Sure.
Recommended? No. Why? Because you aren't asking about a stretched look.
-alex
Old 03-11-2015, 04:05 PM   #11
Jrryjms07
Jrryjms07's Avatar
Drives: 2013 Firestorm
what wheel specs are you running?
Jrryjms07 is offline   Reply With Quote
Old 03-11-2015, 04:40 PM   #12
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
It depends on your goals. If you want to track your car, stretch is not the best option. If you are going for your preferred look then you should do you....
ntron1 is offline   Reply With Quote
Old 03-11-2015, 05:02 PM   #13
mav1178
mav1178's Avatar
So tell me, assuming one is NOT going for the look nor trying to fit aggressive wheels onto stock fendered cars, how is a stretched setup good?
Here's why I think it's bad, ignoring OP's question:
1) stretched tires deform sidewall beyond design characteristics
2) any imperfections or defects in sidewall construction will be exaggerated by stretching tires
3) wheels may have more potential for curb damage, but this is driver-dependent.
4) if stock tires, using it beyond the design characteristics of the tire will impact tire warranty and any normal damage claims that may arise from a tire defect.
Again, let's ignore the slammed/wide wheel/stance argument, and assume stock tires on a stock-height FRS/BRZ with 9" wide wheels as OP is asking about. Please tell me how #1 #2 and #4 are addressed.
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
2much (03-11-2015), Error (03-11-2015), WhiteFRS69 (03-11-2015)
Old 03-11-2015, 07:43 PM   #14
AlexWood
Drives:
Yes they will work fairly well with the 215's. Yes they will be stretched but not to the point where they are un-drivable. Just make sure they are installed by a reputable shop that knows what they are doing. Seeing as you only have springs, I wouldn't go much over a 235 as you may run Into rubbing issues. If you are looking for the stretched look, then a 225 will work just fine.
AlexWood is offline   Reply With Quote
