Old 03-09-2015, 07:38 PM   #1
duke_FRS
duke_FRS's Avatar
Drives: 2015 FRS Hot Lava 2014 CT200H
HIDS don't light up.
I bought 55w 6k HIDS but they don't light up.. Do I need to order the relay harness?
duke_FRS is offline   Reply With Quote
Old 03-09-2015, 07:45 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
uh.
We need a little more description.
A relay is a good idea though.
Have you checked fuses? Wiring?
Old 03-09-2015, 07:45 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
1) Do you have HID projectors, or are you running stock projectors?
2) What brand did you get?
Old 03-09-2015, 08:15 PM   #4
8R6
8R6's Avatar
Drives: FRS
you sure you didnt plug in the wires backwards/flipped around? and 55w is unnecessary. a good 35w kit will be more than sufficient.
8R6 is offline   Reply With Quote
Old 03-09-2015, 08:19 PM   #5
Chimera
Drives: FRS
Assuming that you wired everything right does the halogen still light? If no you should check fuses. If yes you didn't wire it right. 55w is unnecessary. But now that you have it you probably want the harness for reliability.
Old 03-09-2015, 08:30 PM   #6
duke_FRS
duke_FRS's Avatar
Originally Posted by Shutter View Post
uh.
Fuses work. I plugged the old ones and they light up no problem.
Old 03-09-2015, 08:32 PM   #7
duke_FRS
duke_FRS's Avatar
Standard Projector to blind ppl (j/k sorta..)
Kensun h11 I used them on my ISF and CT200h no issues.
Old 03-09-2015, 08:37 PM   #8
HachiRo
Drives: 2013 White-Out FRS
Try flipping the plug that you plug into the stock harness thingy. I'm running Kensuns no problem.
HachiRo is offline   Reply With Quote
Old 03-09-2015, 08:43 PM   #9
duke_FRS
duke_FRS's Avatar
Tried that too.
Old 03-09-2015, 08:45 PM   #10
HachiRo
Did you clip in the other cord hard enough? I forgot the name but you have to push it in really hard.
Old 03-09-2015, 10:33 PM   #11
duke_FRS
duke_FRS's Avatar
Fix!!!! Called my buddy up he had some CAN-BUS: MORIMOTO relaya and they beamed up!
Makes a HUGE difference!!!
Old 03-09-2015, 10:39 PM   #12
swarb
Good job! post pics of the beam pattern on a wall and show us how you are blinding everyone! hahaha
Old 03-09-2015, 10:43 PM   #13
duke_FRS
duke_FRS's Avatar
Tomorrow.. Wife said I cant go outside and play anymore. lol
Old 03-09-2015, 11:04 PM   #14
HachiRo
Make sure to adjust the beams using the two Silver/Grey knobs on the back of the headlights. When I first installed I somehow screwed them to point all the way down. Screwed them up and now I get highs flashed at me every night readjusting tonight.
HIDs and Fog Light Kit TeamTFR Exterior Parts (Aero, Lighting, Etc.) 6 09-22-2014 06:53 AM
Where to look for HIDs? kALMIGHTY Cosmetic Modification (Interior/Exterior/Lighting) 18 04-23-2013 03:17 PM
HIDs 8k DAmarcus28 Cosmetic Modification (Interior/Exterior/Lighting) 37 10-31-2012 04:26 AM
Hids Sh4rp CANADA 3 07-30-2012 12:25 PM
