Drives: Ae86
Rpm drop at idle
Just got my frs last week it's a 2013 with 44xxxkms it has an injen intake. I was going through the service records and it had thrown a check engine code. Toyota said it was because of the intake. Car runs great with no issues, except when I stop occasionally the rpm will drop to around 500rpm then bounce back up. Would the intake be the culprit?
My car is headed in next week to get an ecutek tune. So if the intake is the problem we can fix it with tuning. I'm not 100% familiar with boxer motors just don't want it to end up being something should get warrantied before I void the warranty |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
http://www.ft86club.com/forums/showthread.php?t=21868
See: TSB # S-SB-0040-13 Its the second sticky at the top of this very sub-forum. Your Injen Intake will not cause any idle issues. The code was most likely a MAF sensor code from the car running too lean, or the installer forgetting to plug in the sensor after install. |
Drives: Ae86
I'm in Canada will the tsb be the same? Much thanks for the link
Drives: BRZ Sport-tech
The idle is 600, and RPM drops to 500 momentarily when the AC compressor kicks in.
#5 | |
If you're getting an ECUTek tune, I wouldn't even worry about going to the dealer to get it fixed. AFAIK, the only fix they perform is an ECU reflash. |
#6 | |
Drives: BRZ DGM Limited
Drives: '15 BRZ ISM
Same on my 2015 BRZ MT. I'm fairly sure that's normal behavior on many cars, as that's also the case on my 2000 Camry.
Drives: 2013 Firestorm FRS
pick up an OFT and flash the car...problem solved without going to the dealer and having them mess something up more
The car runs SO much smoother after oft, even if I didn't have mods I would still flash one of the base tunes just to get injector seal fix, idle and others... |
Drives: 2015 FR-S - Halo
Mine performs this, but when at a dead stop and it will continue to do it.
Here is my post that I started to help solve this issue http://www.ft86club.com/forums/showthread.php?t=83160
#10 |
The Fail Boat
Drives: CWP S.B.
Rpm drop at idle
My car does this when AC is on & summer is here soon. But I don't think there is a fix?
#11 |
Not for the compressor related drop there isn't. Just nature of the beast with any smaller displacement engine and AC not a problem.
#12 |
The Fail Boat
Drives: CWP S.B.
Rpm drop at idle
But it's not like it only drops when compressor kick-in thou. It just goes on and off nonstop + My other 4cylinder (RAV4 & CRV) car don't do this.
But I know it's probably just how it is, just worried. |
| Drop it Like its Hot! *Lets See Your Drop* | VIXEN | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 92 | 09-07-2013 02:53 AM |
| brake pump at idle rmp drop? | subaruferrucci | Issues | Warranty | Recalls / TSB | 8 | 12-07-2012 03:45 PM |
| Reported idle-drop and crickets - got turned away | empower-auto | Issues | Warranty | Recalls / TSB | 11 | 10-21-2012 11:36 AM |
| Who is going to buy the FRS DROP DROP Shop? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 10-18-2012 05:45 PM |
| Start-Up Idle Drop (VIDEO) | MidnightMonkey | Issues | Warranty | Recalls / TSB | 18 | 10-02-2012 01:54 AM |
