Old 03-05-2015, 06:18 PM   #1
19eightysix
Drives: Ae86
Rpm drop at idle
Just got my frs last week it's a 2013 with 44xxxkms it has an injen intake. I was going through the service records and it had thrown a check engine code. Toyota said it was because of the intake. Car runs great with no issues, except when I stop occasionally the rpm will drop to around 500rpm then bounce back up. Would the intake be the culprit?
My car is headed in next week to get an ecutek tune. So if the intake is the problem we can fix it with tuning. I'm not 100% familiar with boxer motors just don't want it to end up being something should get warrantied before I void the warranty
19eightysix is offline   Reply With Quote
Old 03-05-2015, 06:25 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
http://www.ft86club.com/forums/showthread.php?t=21868
See: TSB # S-SB-0040-13
Its the second sticky at the top of this very sub-forum.
Your Injen Intake will not cause any idle issues. The code was most likely a MAF sensor code from the car running too lean, or the installer forgetting to plug in the sensor after install.
Bobblehead is offline   Reply With Quote
Old 03-05-2015, 06:56 PM   #3
19eightysix
Drives: Ae86
I'm in Canada will the tsb be the same? Much thanks for the link
Old 03-05-2015, 07:04 PM   #4
PMPB
Drives: BRZ Sport-tech
The idle is 600, and RPM drops to 500 momentarily when the AC compressor kicks in.
PMPB is offline   Reply With Quote
Old 03-05-2015, 07:18 PM   #5
Bobblehead
Bobblehead's Avatar
It should be. I don't know for sure though.
If you're getting an ECUTek tune, I wouldn't even worry about going to the dealer to get it fixed. AFAIK, the only fix they perform is an ECU reflash.
Old 03-05-2015, 07:47 PM   #6
BRZnut
Drives: BRZ DGM Limited
My 2013 is stock and has done that from day one. During quick stops the RPMs will drop from 700 to 550 as I come to the stop , but then quickly go up to 700 (but never stalls)
Old 03-05-2015, 10:54 PM   #7
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
Same on my 2015 BRZ MT. I'm fairly sure that's normal behavior on many cars, as that's also the case on my 2000 Camry.
Lelantas is offline   Reply With Quote
Old 03-05-2015, 10:58 PM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
pick up an OFT and flash the car...problem solved without going to the dealer and having them mess something up more
The car runs SO much smoother after oft, even if I didn't have mods I would still flash one of the base tunes just to get injector seal fix, idle and others...
Old 03-06-2015, 12:03 AM   #9
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
Mine performs this, but when at a dead stop and it will continue to do it.
Here is my post that I started to help solve this issue
http://www.ft86club.com/forums/showthread.php?t=83160
Sugi is offline   Reply With Quote
Old 03-06-2015, 08:16 PM   #10
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Rpm drop at idle
My car does this when AC is on & summer is here soon. But I don't think there is a fix?
Old 03-06-2015, 08:37 PM   #11
Not for the compressor related drop there isn't. Just nature of the beast with any smaller displacement engine and AC not a problem.
Old 03-06-2015, 09:03 PM   #12
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Rpm drop at idle
But it's not like it only drops when compressor kick-in thou. It just goes on and off nonstop + My other 4cylinder (RAV4 & CRV) car don't do this.
But I know it's probably just how it is, just worried.
Drop it Like its Hot! *Lets See Your Drop* VIXEN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 92 09-07-2013 02:53 AM
brake pump at idle rmp drop? subaruferrucci Issues | Warranty | Recalls / TSB 8 12-07-2012 03:45 PM
Reported idle-drop and crickets - got turned away empower-auto Issues | Warranty | Recalls / TSB 11 10-21-2012 11:36 AM
Who is going to buy the FRS DROP DROP Shop? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-18-2012 05:45 PM
Start-Up Idle Drop (VIDEO) MidnightMonkey Issues | Warranty | Recalls / TSB 18 10-02-2012 01:54 AM
