Old 03-05-2015, 12:05 PM   #1
BadLuckZN6
BadLuckZN6's Avatar
Drives: GT86
Oil cooler for HKS V2 supercharger
Do I have to run the HKS oil cooler that tucks behind the light if I have the V2 supercharger kit.
I have a RHD car and the Intercooler seems to sit to the left where a lot of aftermarket intercoolers are positioned. What are you guys running with the HKS Supercharger? i wanted to buy Sard but not sure it will fit.
BadLuckZN6 is offline   Reply With Quote
Old 03-05-2015, 12:38 PM   #2
FRSCanuck
Drives: Scion FRS
not sure about SARD, i ended up running the HKS oil cooler.
FRSCanuck is offline   Reply With Quote
Old 03-05-2015, 05:50 PM   #3
HaDDeS
Touge worship
HaDDeS's Avatar
Drives: Forester STi SG9
I have the HKS V2 S/C on my BRZ so i know that setup pretty well
Yes, you HAVE to install an oil cooler, the easiest solution is the HKS oil cooler for S/C setup it works perfectly with the supercharger layout.
this is what you are looking for:
http://www.hks-power.co.jp/en/produc...oling/db/15613
I wouldn't go any other route, I understand it is probably not the cheapest one, but the HKS v2 kit + tunning isn't cheap either, so it is totally worth the money all together
HaDDeS is offline   Reply With Quote
Old 03-05-2015, 10:47 PM   #4
BRZ888
BRZ888's Avatar
Drives: 2014 Toyota GT86
i just want to confirm that you installed the HKS SC VERSION 2 with oil cooler with part number 15004-AT011?
How many quarts of oil did you add after you install the oil cooler?
How many hp did you gain after you tuned?
Thank you
BRZ888 is offline   Reply With Quote
Old 03-06-2015, 07:11 AM   #5
HaDDeS
Touge worship
HaDDeS's Avatar
Thank you
Yes it is the part number 15004-AT011 , and it adds about 1.5L of oil
As for the power, my result can't be compared to a normal V2 setup as I have the stroker kit, Vcams , and injectors but you still can check on my build thread
Old 03-06-2015, 03:02 PM   #6
BadLuckZN6
BadLuckZN6's Avatar
Drives: GT86
Thanks, i ordered the HKS cooler just for peace of mind. As you said its not the cheapest but at least ill know it fits without any kind of messing around. Did you remove your fog or do anything to route air to the cooler?
Old 03-06-2015, 06:28 PM   #7
HaDDeS
Touge worship
HaDDeS's Avatar
The cooler is actually exposed through the wheelwell, it requires to trim the plastic wheelwell, and put a grid for protection, no need to touch the fogs
Great buy ! peace of mind with a oil cooler makes a difference
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
oil cooler for innovate supercharger Benn0r Forced Induction 15 11-11-2015 10:09 AM
Perrin Crank Pulley, Pulleys, Vortech Supercharger, Chase Bays Oil Cooler, Chase Bays Engine, Exhaust, Bolt-Ons 26 01-05-2015 05:20 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 02:00 AM
What oil cooler kits do you have installed alongside your JR supercharger? Venator Forced Induction 11 07-14-2014 05:29 PM
