Old 07-15-2013, 02:07 AM   #1
Benn0r
Drives: 2013 Toyota 86 GTS
oil cooler for innovate supercharger
i have decided to get an oilcooler for my innovate\sprintex\bullet supercharger. has anyone installed one in their car? i have heard that the hks, greddy are the good options.
ideas?
Benn0r is offline   Reply With Quote
Old 07-15-2013, 02:27 AM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Oil cooler for the oil in the supercharger or just an oil cooler for the engine in general? I installed the Perrin oil cooler and it has dropped the oil temp around 20 degrees when on the freeway. Install was fairly simple with the hardest part taking off the front bumper.
stockysnail is offline   Reply With Quote
Old 07-15-2013, 02:43 AM   #3
Benn0r
engine in general, down in australia we have an intercooled innovate option which means that we just need an oil cooler for things like track days etc.
Cheers!
Old 07-15-2013, 01:08 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I installed the Full Blown oil cooler two weeks ago. Great option for forced induction cars as it doesn't block intercoolers/heat exchangers:
Old 07-15-2013, 01:12 PM   #5
TemeCal
Drives: 86
If there is any chance of having @robispec ship you one of his coolers, I'd go that route. IMO, his solution is one of the best I've seen. I know you were just looking for an oil cooler, but his comes with a massively upgraded radiator as well. Well worth the money if you can pick one of these up!
Several others are running his cooling solution with the Innovate supercharger.
TemeCal is offline   Reply With Quote
Old 07-15-2013, 01:35 PM   #6
sw20kosh
Drives: 2013 Black FR-S
^ what he said
If you want a larger radiator too, and an Oil-to-Water Oil cooler try looking into @robispec Cooling Solution
It works great on my innovate set up. Ran it at the track in 100+ deg weather and it worked beautifully.
Here are some logs of temps on the dyno. 6 WOT 4th gear runs with ~5 mins in between each. This shows the 1st and last pull to demonstrate there is no heat soak and temps are kept in-line.
http://www.ft86club.com/forums/showp...&postcount=143
Old 07-15-2013, 01:54 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am not sure that 6 runs over the course of 30 minutes on a dyno with the hood open and fans blowing is the best example of how well a cooling solution works.
Old 07-15-2013, 02:04 PM   #8
sw20kosh
Never said it was the best test. It is the only data I have right now.
Now that I know how to data log I plan on doing some logging next time I am at the track. (As far as track temps go all I have right now is anecdotal evidence on Robi and my car which performed well. I do know he just ran a time attack at chuckwalla in 116 deg heat and he says fluid temps were good.)
Old 07-15-2013, 02:12 PM   #9
jamesm
I've yet to see my coolant temps rise above what they were stock, and I've been beating the hell out of my car since the turbo got installed. I think our stock radiator is sufficient, definitely for street cars. Haven't tracked it yet though.
Old 07-15-2013, 02:19 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Nice ninja edit. The true test is a log of coolant/oil temps during a 20 minute session on track.
Old 07-15-2013, 02:29 PM   #11
sw20kosh
Old 07-15-2013, 02:30 PM   #12
Dezoris
Dezoris's Avatar
It's the recovery time that is different, and overall efficiency and resistance to heat soak that makes the larger radiator important.
Stock vs aftermarket rad in open air low load there is no difference, on and off hard throttle in open air there is marginal difference.
The major difference is idle/dirty air and full load for extended time frames. That's when you see the temps on the aftermarket radiator recover 30-40% faster.
You have to look at idle temps with no air flow, high load temps, and cruising temps to see the whole picture.
Old 07-21-2014, 10:49 PM   #13
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Months have passed since this thread has been posted. Have more Innovative owners been installing oil coolers with their Stg 1 SC or left it stock?
Anyone care to share their temperatures with or without an oil cooler while at idle, cruising or under heavy load?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 07-21-2014, 11:12 PM   #14
xjohnx
Grip>Slip
xjohnx's Avatar
I went with the Perrin oil cooler. Easy install, perfect fit, very happy overall. The mishimoto will not fit with the intercooled innovate kit.
it's been a while since i paid close attention to the temps, but if i recall i was hitting ~240 degrees before the oil cooler, i don't think i have seen the oil temps exceed ~215 since installing the oil cooler.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Innovate Stg1 Supercharger with W/M injection sw20kosh Forced Induction 180 09-23-2013 04:30 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
