Drives: 2013 Raven FR-S
front camber help
I'm looking to get -1.5 front camber on my FRS. What's the easiest way to achieve that? Can I just use the OEM bolts or do I need camber bolts? Also, are you supposed to use the top or bottom holes? I've read a lot of conflicting info and it's getting confusing.
Undisputed El Presidente
Drives: Zenki 37J ZN6
14mm oem crash bolt goes in the upper hole. 16mm eccentric camber bolt (spc, whiteline, etc) goes in the upper hole. 14mm eccentric camber bolt goes in the lower hole.
I run spc in the lower hole and crash bolt in the upper and get max -2.5 front. Not sure if one or the other alone gets 1.5. |
16MM eccentric in the upper alone was not enough for my tech to go past -1.2, but your experience may vary. The guy's a wizard and wasn't being lazy- he showed me on their rig the max he could push it. I tried going for -1.5
(Everett Firestone) |
Drives: FRS
max i was able to get with my whiteline camber bolts up top was -1.3deg. like mentioned above, results seem to vary slightly. some were able to get 1.5 and some less.
I got about -1.5 on each side with just whiteline bolts in the upper holes, slightly slotting the upper holes got me to -2.
Drives: Black BRZ
I max out at -1.45 with just the upper camber bolts
Drives: 2015 Ultramarine FR-S MT
I have SPC camber bolts in the lower hole, maxed out at -1.7LF, -1.8 RF
-1.5 with OEM crash bolts in the upper holes here.
To get much beyond that you need to slot the holes or use camber bolts in both holes. |
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
| WTB Front Camber bolts | manualmotive | Want-To-Buy Requests | 2 | 04-17-2014 02:45 AM |
| Need more camber up front | gk | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 02-16-2014 06:13 AM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
