Old 03-03-2015, 05:46 PM   #1
matthui95
matthui95's Avatar
Drives: 2018 CWP Subaru BRZ Sport-tech RS
New Heated Seats System?
Probably a noob question. But, just wanted to see if I could get anything done about this.
As you guys probably know, our heated seats aren't the best out there. My parents just bought a 2015 Ford Escape Titanium and I find that those heated seats are great; 5 different levels of heat and the heat can get pretty hot, which is great considering I live in Toronto .. our winters are absolutely horrible.
Is it possible to get the heating pads (or whatever it is) as well as the heated seats switches into the BRZ? I would like to somehow have the Escape's entire heated seats system in my BRZ. Any insight on this would be great!
Here's a picture of what I'm talking about. Willing to modify that into two smaller controls (like the ones we have now) instead of one giant panel. Can do without the 12V.
matthui95 is offline   Reply With Quote
Old 03-03-2015, 07:26 PM   #2
sirsol66
Drives: 2013 FRS- Hot Lava
We have the same system in our Focus ST and I would give almost anything to have it in the FR-S. One of the things Ford got very, very right.
sirsol66 is offline   Reply With Quote
Old 03-03-2015, 08:44 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://www.ft86club.com/forums/showthread.php?t=83712
Old 03-03-2015, 10:10 PM   #4
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
youre welcome lol
http://www.clazzio.com/hsk2-sa.php
mrlewistan is offline   Reply With Quote
Old 03-03-2015, 11:16 PM   #5
matthui95
matthui95's Avatar
Agreed! Although I haven't tried THAT many different heated seats, I don't want to use something else other than Ford's now.
Originally Posted by cdrazic93 View Post
FR-S's don't come with heated seats, so it's probably just a heating pad between the seat cover and the actual seats.
Originally Posted by mrlewistan View Post
Would be nice, but I still want to have Ford's heated seat system in the BRZ Just me being picky. But, I guess this means that I can somehow rip out the current heated seat system and put the Clazzio (or Ford's, if I can figure it out) system in ..
Old 03-04-2015, 01:28 AM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
yes, he had a heating element installed when he re-wrapped the seats.
Old 03-05-2015, 01:45 AM   #7
sidewayzfrs
Drives: black 2014 frs
I have heated seats in my frs but I never use them I know the seats in my bimmer were just a pad with heating wires shouldn't be to hard to modify
sidewayzfrs is offline   Reply With Quote
Old 03-05-2015, 11:23 AM   #8
qoncept
qoncept's Avatar
"Just" ? That's how seats are heated.
qoncept is offline   Reply With Quote
Old 03-05-2015, 01:38 PM   #9
Joeprelude
Joeprelude's Avatar
Drives: 2013 FRS, 2002 WRX Wagon
Step 1. Get frs/brz heated seat pads. Step 2. Get controls for Ford whatever. Step 3. Figure out wiring for Ford controls. Step 4. Find place to install Ford Controls. (Hardest part) Step 5. Wire it up and install controls. Step 6. Never freeze but in car again.
But seriously, If you can get a wiring diagram of the ford control unit, it shouldn't be too hard, except for mounting the controls. Each thing with a number is probably just a variable resistor changing the power input to the heating pads. The rest is an accessory 12v going into the control switch, power from controls to pad, then pad to a ground (for each).
Joeprelude is offline   Reply With Quote
Old 03-05-2015, 08:24 PM   #10
matthui95
matthui95's Avatar
Would installing the Ford controls with the BRZ heated seat pads provide me with as much heat as I get in our Ford? Or would the heat be limited/bottlenecked by the pads that are already in the BRZ? (Meaning I'd have to get new ones)
Old 03-05-2015, 08:42 PM   #11
bfsnail
bfsnail's Avatar
I'm fairly certain that new controls wont change the amount of heat going to your pads. The controls should just control how the energy gets to your pads, not the total amount delivered/usable. At best, you would have the 5 setting on the Ford controller being the same temp as the high setting on the OEM one.
bfsnail is offline   Reply With Quote
Old 03-05-2015, 11:30 PM   #12
Joeprelude
Joeprelude's Avatar
This is correct.
Old 03-06-2015, 02:38 AM   #13
matthui95
matthui95's Avatar
I guess installing just the new controls would be useless and definitely not worth the work needed. Looks like new heating pad + new controls is the way to go .. if I can figure out how and where to install the controls.
Doesn't seem like there's any good areas to place such a big panel. Suggestions anyone?
Old 03-06-2015, 10:08 AM   #14
qoncept
qoncept's Avatar
In the console? Honestly I think sourcing a 5-way switch and building your own circuit would be the way to go.
heat, heated seats, mod, seats
DIY – OEM Heated Seats @Art_Mighty DIY (Do-It-Yourself) Guides 22 12-30-2020 05:38 AM
OEM wiring for heated seats Basti Electronics | Audio | NAV | Infotainment 7 01-04-2019 01:34 PM
heated seats debs0712 Cosmetic Modification (Interior/Exterior/Lighting) 47 04-08-2018 09:06 PM
Heated seats not very good? Mossyjaw BRZ First-Gen (2012+) — General Topics 59 03-31-2014 09:08 AM
How Do I get FR-S Heated Seats? 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 5 03-01-2014 07:45 PM
