Old 03-02-2015, 08:42 PM   #1
lokiwho
lokiwho's Avatar
Drives: 15' Halo FR-S 6MT
Ringing / Pinging from under center console
Recently I've noticed that @ about 3K RPM and above I can hear this ringing/vibrating sound coming from under the stick or maybe the stick itself? The more I accelerate, the louder it gets. It almost sounds like 2 pieces of metal that are vibrating closely together. If I'm in gear and I hold the stick and move it to the left or right the sound changes a bit. It's really weird and I hope that it's not anything to do with my transmission / drive shaft.
I've tried to diagnose by taking off the center console and trying to listen to see if its the metal reverse lockout plate but as you can imagine the noise from underneath the car with all the stuff off is pretty loud. I have a Kartboy short shifter and really cannot find the problem worth a damn. I'd like to think I'm pretty good about this stuff.
Anybody have this type of issue
I'm running Motul 300 in the tranny/diff. Yes I used the proper amount of fluid in both.
I know there's been some vibrating problems with the stick in past posts,
http://www.ft86club.com/forums/showthread.php?t=11503
not sure if this is the issue, i'll try removing the knob to see how that turns out.
Thanks in advance
Alex
lokiwho is offline   Reply With Quote
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
need help on jpm center console Jhon19lopez Cosmetic Modification (Interior/Exterior/Lighting) 4 06-24-2013 07:57 PM
red center console? gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 13 02-19-2013 08:03 PM
Center Console help mbh1101 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-22-2012 09:56 AM
Center Console encity5 Electronics | Audio | NAV | Infotainment 1 06-10-2012 09:22 AM
